> is it possible ?, to install the axle with the spindle attached
hedgehog
post Jun 27 2014, 08:25 PM
i sheared the bolts that attach the cv joint to the spindle at the parade autocross...i assume they backed out slightly and when i was shifting into 3rd on a left hand sweeper...boom...that was it and i had to park it... took it apart and was hoping to wire tie it while it is out of the vehicle where it is easier to work on but getting it back in with the spindle attached is not working....any suggestions aside from dropping the motor....?
Mike Bellis
post Jun 28 2014, 07:51 AM
Resident Electrician
I've done it a few times and is easy if you get the tranny side above or below the tranny to make room to pull out the assembly.
hedgehog
post Jun 28 2014, 10:16 AM
QUOTE(Mike Bellis @ Jun 28 2014, 06:51 AM) *
it's not getting it out....it's getting it in that i'm having trouble with...lining up the spines is a PITA... (IMG:style_emoticons/default/blink.gif)
Mike Bellis
post Jun 28 2014, 01:13 PM
QUOTE(hedgehog @ Jun 28 2014, 09:16 AM) *
I never had a problem. A couple of wiggles and twist and it slides in...
- Lo-Fi Version Time is now: 27th June 2026 - 08:10 AM
