> Transmission identify/info
zdaxxy
post Jun 30 2014, 07:10 AM
My 1974 914 I bought did not come with an engine or transmission. I bought this off craigslist titled as '914 transmission for sale'
Guy didnt know anything about it. Said it was a 5 speed that was pulled from a running 914 and shifted fine, no known issues, blah blah...
Oh he said this is a tail shift?
I only found two numbers on it. Cant seem to locate a manual for specifications.
I need to get a clutch for it, replace the seals since its out, replace the oil, etc.
Are there manuals for this?? With these numbers is there a way to reference what year/type etc?
Also, what is the little two prong switch? backup/reverse switch or vacuum sensor?
914.301.301.03
914.301.101.00
Im slightly confused about the numbering of the transmissions.
Did a Porsche 914 car come with a 901 trans, a 914 trans, or either depending on year?
This first number 914. designate this is a 914 trans? or for a 914 car?
Dave_Darling
post Jun 30 2014, 08:42 AM
914 Idiot
Originally, the 911 was called the "901". The number for the car was changed very early on, but many of the parts still carried that as the first number grouping.
The 914 used a version of the early 911 transmission, but set up for mid-engine operation. So the 914 transmission is based on the 901 transmission, rather than the later 915 box from a 72-86 911, for example.
We often call the 914's transmission a "901" because of all of the elements that it has in common with those early 911 transmissions, but if we were to be specific we probably ought to say "914 transaxle".
Yours is definitely a tail-shift; the linkage goes into the box through the tail-cone. A side-shift would go in through the case in front of the intermediate plate.
The transmission serial number should be located on the bottom of the gearbox, on the lowest fore-and-aft rib.
--DD
- Lo-Fi Version Time is now: 25th September 2026 - 07:05 PM
