| Harpo |
Jul 3 2014, 12:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
| ClayPerrine |
Jul 3 2014, 01:38 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Make up two jumper wires with one male spade connector and 3 female spade connectors. Make one with red wires, and the other with brown wires. Hook the red ones to the positive connectors on the back of each gauge, and the brown ones on to the negative or ground connectors.
Hook the sender wires up to the proper senders, put the lights in the gauge cluster and put it in the dash. |
Harpo Wiring of my triple gauge Jul 3 2014, 12:12 PM
Harpo For starters can the stock oil temp sender on my 4... Jul 3 2014, 12:15 PM
Cap'n Krusty The sender must be matched to the gauge. There ar... Jul 3 2014, 01:34 PM
Harpo The 911 sender has two wires. Is one of those a g... Jul 3 2014, 02:23 PM
ClayPerrine
The 911 sender has two wires. Is one of those a ... Jul 3 2014, 02:28 PM
Dave_Darling Look for markings on the plastic part of each conn... Jul 3 2014, 03:03 PM
Harpo Somewhere I read here that this was the correct se... Jul 3 2014, 04:48 PM
Harpo Per the captain's comment do I need a 911 temp... Jul 3 2014, 04:49 PM
Brian_Boss That sender looks like a Bosch aftermarket sender ... Jul 3 2014, 04:59 PM
Harpo Each one of the gauges does have identification
G... Jul 3 2014, 05:09 PM
Harpo Thanks Brian. I have the 80 PSI dual sender
Davi... Jul 3 2014, 05:10 PM
Harpo Here is a matched 911 sender & gauge but they ... Jul 4 2014, 08:57 AM
bdstone914
Here is a matched 911 sender & gauge but they... Jul 4 2014, 10:53 AM
bdstone914
[quote name='Harpo' post='2057446' date='Jul 4 20... Jul 4 2014, 10:59 AM
Harpo Bruce, I got the gauge from you. I will check my ... Jul 4 2014, 10:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th December 2025 - 11:04 PM |
