| Harpo |
Jul 3 2014, 12:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
| Brian_Boss |
Jul 3 2014, 04:59 PM
Member ![]() ![]() Group: Members Posts: 324 Joined: 3-June 03 From: Dallas, TX Member No.: 781 |
That sender looks like a Bosch aftermarket sender with both a switch (idiot light) and sender (gauge). I believe all 911's had a separate sender/switch. There are at least two PSI ranges but if you have the right one it works fine w/ the 911 instrument - that's what I have in mine.
Range and function of the terminals s/b marked on sender but may be hard to read. P.S. For 0 - 5 BAR gauge, I believe the sender you want should say 0-80PSI on it. |
Harpo Wiring of my triple gauge Jul 3 2014, 12:12 PM
Harpo For starters can the stock oil temp sender on my 4... Jul 3 2014, 12:15 PM
Cap'n Krusty The sender must be matched to the gauge. There ar... Jul 3 2014, 01:34 PM
ClayPerrine Make up two jumper wires with one male spade conne... Jul 3 2014, 01:38 PM
Harpo The 911 sender has two wires. Is one of those a g... Jul 3 2014, 02:23 PM
ClayPerrine
The 911 sender has two wires. Is one of those a ... Jul 3 2014, 02:28 PM
Dave_Darling Look for markings on the plastic part of each conn... Jul 3 2014, 03:03 PM
Harpo Somewhere I read here that this was the correct se... Jul 3 2014, 04:48 PM
Harpo Per the captain's comment do I need a 911 temp... Jul 3 2014, 04:49 PM
Harpo Each one of the gauges does have identification
G... Jul 3 2014, 05:09 PM
Harpo Thanks Brian. I have the 80 PSI dual sender
Davi... Jul 3 2014, 05:10 PM
Harpo Here is a matched 911 sender & gauge but they ... Jul 4 2014, 08:57 AM
bdstone914
Here is a matched 911 sender & gauge but they... Jul 4 2014, 10:53 AM
bdstone914
[quote name='Harpo' post='2057446' date='Jul 4 20... Jul 4 2014, 10:59 AM
Harpo Bruce, I got the gauge from you. I will check my ... Jul 4 2014, 10:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th December 2025 - 11:02 PM |
