Saved From the Car Crusher!, Maybe parts should have been crushed???? |
PlantMan |
Jul 4 2014, 12:13 AM
Member Group: Members Posts: 438 Joined: 14-May 14 From: Mission Viejo Member No.: 17,352 Region Association: Southern California |
Hey All,
I saved this car, I am sure, from pending doom as it was sitting in a Coparts yard in the SF Bay area, not to mention it was donated to charity........ I thought it had potential so I scooped it up. My last 914 was a 1.7 (72) and I always wanted the 73-74 2.0l, so here we are. Anyways, you can see from the attached photos she is a little long in the tooth!!! BTW, this car is a true California car and appears to have spent it's entire life in NorCal. Who said Cal cars have little rust??? It also appeared to have a trans change-out around 30k miles, interesting. I have gone through 80% so far, got the car up and running, fixed a majority of the oil leaks, and now getting the brakes sorted out so I can road test it. Interior is in very good shape, minus the carpet, dashboard is a solid A grade for 40 years old and the seats and back pad are still quality as well. I am debating the AC system, which I will remove for now, but it might go back in in the future. The motor starts right-up without any problems and after I get the brakes back on I am going to check for vacuum leaks, it has a high idle but I think maybe the AAR maybe stuck. Debating the next step, starting from the front of the car and possibly working my way to the back, doing the body work. I am trying to gather pieces now for the sheet metal clean-up. Enjoy the photos! I did add it to the VIN database as well. [attachmentid=457 680] [attachmentid=457 688] Attached image(s) |
Java2570 |
Jul 4 2014, 06:15 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
Looks like a lot of good parts on that one.....my opinion is if you are going to do rust repair, strip it all down and see what you have afterwards. Lots of rust likes to hide in the lower firewall/floor area on passenger side. You have structural rust in the hellhole and longs that needs to be assessed. That rust in the front cowl is not a good sign and can be a tricky repair. It definitely has cancer.....dig deeper and see if it's something you want to tackle as a long term project or you can always look for a better tub to use some of the good parts on.
Lo-Fi Version | Time is now: 9th June 2024 - 11:18 PM |
