| Harpo |
Jul 3 2014, 12:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
| Harpo |
Jul 4 2014, 08:57 AM
Here is a matched 911 sender & gauge but they want $200
http://www.pelicanparts.com/cgi-bin/smart/...%34%2D%38%39%29 Does anyone know if I can use the 914 sender (free) or do I have to use the 911 sender for $67? Are the threads the same? Thanks David |
| bdstone914 |
Jul 4 2014, 10:53 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,216 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Here is a matched 911 sender & gauge but they want $200 http://www.pelicanparts.com/cgi-bin/smart/...%34%2D%38%39%29 Does anyone know if I can use the 914 sender (free) or do I have to use the 911 sender for $67? Are the threads the same? Thanks David To answer that question you need to know what year 911 temp gauge is used. I believe is was 1974 where the sending unit changed. You can bench wire it with the 914 sender and see if it responds to heating the sender. If it goes up you can use the 914 sender. If you have a later 911 gauge the sender works opposite. I think the early senders decreased in resistance as the temperature increased. Later senders increased in resistance as the temp increased. |
| bdstone914 |
Jul 4 2014, 10:59 AM
Here is a matched 911 sender & gauge but they want $200 http://www.pelicanparts.com/cgi-bin/smart/...%34%2D%38%39%29 Does anyone know if I can use the 914 sender (free) or do I have to use the 911 sender for $67? Are the threads the same? Thanks David To answer that question you need to know what year 911 temp gauge is used. I believe is was 1974 where the sending unit changed. You can bench wire it with the 914 sender and see if it responds to heating the sender. If it goes up you can use the 914 sender. If you have a later 911 gauge the sender works opposite. I think the early senders decreased in resistance as the temperature increased. Later senders increased in resistance as the temp increased. I have a couple of 911 senders but I think they are the early type. I think that temp gauge was not used in 911 until 74 so you are probably going to need the 911 sender. |
Harpo Wiring of my triple gauge Jul 3 2014, 12:12 PM
Harpo For starters can the stock oil temp sender on my 4... Jul 3 2014, 12:15 PM
Cap'n Krusty The sender must be matched to the gauge. There ar... Jul 3 2014, 01:34 PM
ClayPerrine Make up two jumper wires with one male spade conne... Jul 3 2014, 01:38 PM
Harpo The 911 sender has two wires. Is one of those a g... Jul 3 2014, 02:23 PM
ClayPerrine
The 911 sender has two wires. Is one of those a ... Jul 3 2014, 02:28 PM
Dave_Darling Look for markings on the plastic part of each conn... Jul 3 2014, 03:03 PM
Harpo Somewhere I read here that this was the correct se... Jul 3 2014, 04:48 PM
Harpo Per the captain's comment do I need a 911 temp... Jul 3 2014, 04:49 PM
Brian_Boss That sender looks like a Bosch aftermarket sender ... Jul 3 2014, 04:59 PM
Harpo Each one of the gauges does have identification
G... Jul 3 2014, 05:09 PM
Harpo Thanks Brian. I have the 80 PSI dual sender
Davi... Jul 3 2014, 05:10 PM
Harpo Bruce, I got the gauge from you. I will check my ... Jul 4 2014, 10:55 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th December 2025 - 11:02 PM |
