914 transmission, 914 transmission |
Jesper2803 |
Jul 7 2014, 12:27 PM
Newbie Group: Members Posts: 13 Joined: 7-July 14 From: Denmark Member No.: 17,595 Region Association: None |
Hello.. My 914 transmission is making an (whining) sound when im driving its apperes en all gears but its worst in fourt and fift... The gears shifts perfekt and i just poured ind new swepco oil.... Is this a bearing????
Thanks jesper. Denmark. |
stugray |
Jul 7 2014, 01:09 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
An improperly set pinion depth is known for making that kind of noise.
Was the trans recently "rebuilt"? Has it always done it? Did it make the noise before you added the new oil? What weight oil did you use? |
Jesper2803 |
Jul 7 2014, 01:17 PM
An improperly set pinion depth is known for making that kind of noise. Was the trans recently "rebuilt"? Has it always done it? Did it make the noise before you added the new oil? What weight oil did you use? I used swepco 201. The noice was there before... And its eksaktly the same.. I hawe no info about a rebuild... And there is no signs it has been opened recently. How do i chek that pinion??? Thanks☺️ |
Lo-Fi Version | Time is now: 9th June 2024 - 06:52 PM |
