Converting 1 turn signal to 2 |
patssle |
Jul 10 2014, 03:03 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Swapping out tachs for my /6 conversion - the 911 tach has left and right turn signals vs. just one light for the /4 tach. I've found the instructions to do this but I'm a little confused. The blue/white wire from the turn signal flasher feeds the single light on the /4 tach. The instructions say to split this to both lights on the /6 tach - then run 2 wires from the emergency flasher that feed the exterior front/rear lights.
If those 2 wires are feeding the exterior lights and the blue/white wire feeds the interior light - isn't that 2 positives feeding each other if I hook them all to the tach lights? |
Eric_Shea |
Jul 10 2014, 04:39 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE Notice how the right indicator is connected to the left turn signal bulbs and left indicator to the right turn signal bulbs. So after connecting the blue/white wire to ground, you will swap the left and right indicators in the tachometer. That's the back of the tach... Why would the relay need two grounds? |
Lo-Fi Version | Time is now: 9th June 2024 - 06:48 PM |
