Converting 1 turn signal to 2 |
patssle |
Jul 10 2014, 03:03 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Swapping out tachs for my /6 conversion - the 911 tach has left and right turn signals vs. just one light for the /4 tach. I've found the instructions to do this but I'm a little confused. The blue/white wire from the turn signal flasher feeds the single light on the /4 tach. The instructions say to split this to both lights on the /6 tach - then run 2 wires from the emergency flasher that feed the exterior front/rear lights.
If those 2 wires are feeding the exterior lights and the blue/white wire feeds the interior light - isn't that 2 positives feeding each other if I hook them all to the tach lights? |
patssle |
Jul 10 2014, 07:48 PM
I didn't bother to ground the blue/white wire. Just disconnected it because the lights ground through the gauge. Works great!
Lo-Fi Version | Time is now: 9th June 2024 - 11:50 PM |
