Sill cover cracks?, common issue? |
falcor75 |
Jul 16 2014, 03:09 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Both my sill covers have small crack from the underside and about an inch upwards about 10-12 inches in from the rear end, since both mine are cracked in the exakt same place I'm wondering if this is a common issue?
I'm going to drill a hole at the end of the crack and then weld them back up. Will probably weld up the jack holes to achieve a smooth look on the sill covers while I'm at it. (IMG:style_emoticons/default/welder.gif) |
GeorgeRud |
Jul 16 2014, 06:39 AM
Advanced Member Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Carefully check your longitudinals under the rocker panels to be sure they're not rusting.
falcor75 |
Jul 16 2014, 10:33 AM
Lo-Fi Version | Time is now: 7th June 2024 - 03:10 PM |
