| horizontally-opposed |
Jul 16 2014, 06:07 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,456 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None
Porsche lists the 215/60R15 as an N1 tire approved for 914-6, and I am considering them as they solve the too-small diameter problem I want to avoid. Currently, I'm on 195/65s. I used to run 205/55s and 205/60s, but all of these are too small in diameter.
I know the cars vary, but I was able to run various 205/55s with no rubbing and 205/60 Yoko A008Rs years ago with only a bit of rubbing on the inside (too much negative camber at that time). I'd be running these on 15x6 911 wheels, but may pop to have them turned into 15x7Rs by Weidman and do custom spacers. Big thing is to get a summer performance tire in there with, well, performance—and the right look. That period look with any kind of performance is getting tough to find. If anyone has 215/60s on a narrow car, and can provide pics, I'd be very thankful! (IMG:style_emoticons/default/beerchug.gif) pete |
| rick 918-S |
Jul 16 2014, 10:36 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,370 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
Porsche lists the 215/60R15 as an N1 tire approved for 914-6, and I am considering them as they solve the too-small diameter problem I want to avoid. Currently, I'm on 195/65s. I used to run 205/55s and 205/60s, but all of these are too small in diameter. I know the cars vary, but I was able to run various 205/55s with no rubbing and 205/60 Yoko A008Rs years ago with only a bit of rubbing on the inside (too much negative camber at that time). I'd be running these on 15x6 911 wheels, but may pop to have them turned into 15x7Rs by Weidman and do custom spacers. Big thing is to get a summer performance tire in there with, well, performance—and the right look. That period look with any kind of performance is getting tough to find. If anyone has 215/60s on a narrow car, and can provide pics, I'd be very thankful! (IMG:style_emoticons/default/beerchug.gif) pete I ran 215's on 8's but I had spacers and flares. I know what you mean about "the look" That vintage stance. tires with sidewalls that are tall enough to look tucked without removing all the suspension travel. I had tires from the tire rack. I put them on Sandy's 14 and didn't like them. I went back to the tire rack the next day to order another set. Instead of making me eat them they took them back. dis-mounted them ands mounted a taller set no charge. I mention this because if you ask ahead they my do that for you as a test fit. It's worth a shot. |
Jul 16 2014, 10:41 PM
I ran 215's on 8's but I had spacers and flares. I know what you mean about "the look" That vintage stance. tires with sidewalls that are tall enough to look tucked without removing all the suspension travel. I had tires from the tire rack. I put them on Sandy's 14 and didn't like them. I went back to the tire rack the next day to order another set. Instead of making me eat them they took them back. dis-mounted them ands mounted a taller set no charge. I mention this because if you ask ahead they my do that for you as a test fit. It's worth a shot. Those 215/60s are part of what sold me on your car, Rick. That thing stopped me in my tracks when it was here. Just sooooo right. Might have been what got me off of 205/55s. Was around that time that my taste started changing. First time I saw the 215/60R15 P6000s on the back of an RS 2.7, I was well and truly hooked. Sneaking them under the back of a narrow 914 might not be easy, but may be worth a try—especially since I have to repaint both sides of the car anyway. Only question is whether I have the wheels modified to 7Rs or cram the 215s onto the 6s. I think the 6s will keep the tire a bit narrower, and are within the range of approved rim widths for the Pirellis. Worst case, I try it and I have to widen the wheels later. Tire Rack is almost impossible to beat in terms of customer service. Almost makes me want to move there, as there are few things I rue more in the Bay Area than getting tires mounted and balanced. pete |
horizontally-opposed Has anyone snuck a 215/60R15 into a narrow 914? Jul 16 2014, 06:07 PM
SirAndy All you need is a baseball bat ...
:smash: Jul 16 2014, 06:20 PM
Bruce Hinds I'm running Falken 215/60 x 15 all the way aro... Jul 16 2014, 06:40 PM
I'm running Falken 215/60 x 15 all the way ar... Jul 16 2014, 10:36 PM
Eric_Shea Your future is calling...
http://www.914world.com... Jul 16 2014, 07:09 PM
http://www.914world.co... Jul 16 2014, 10:37 PM
boxsterfan I've got 205/60/15 on 2.0L Fuchs on my narrow ... Jul 16 2014, 09:30 PM
Mike Bellis I'll loan you my fender roller. Let me know...... Jul 16 2014, 11:12 PM
McMark It's all about offset. ;) Jul 17 2014, 02:21 AM
Wdunster I have 225 50 16 on the rear with stock quarters. ... Jul 17 2014, 08:26 PM
mgp4591
I have 225 50 16 on the rear with stock quarters.... Jul 18 2014, 12:10 AM
Dave_Darling I didn't roll the quarters either.
Maybe you ... Feb 7 2016, 11:54 AM
Keyser Sose Here, some 215x45x16 on 7" 911 SC Fuchs, fron... Jul 18 2014, 01:41 PM
rick 918-S
Here, some 215x45x16 on 7" 911 SC Fuchs, fro... Feb 7 2016, 11:51 AM
Porschef Here, some 215x45x16 on 7" 911 SC Fuchs, fron... Feb 7 2016, 01:25 PM
Mhead Will the 215/60's fit the 5 1/2 steel wheels? ... Feb 7 2016, 11:40 AM
Bruce Hinds
Will the 215/60's fit the 5 1/2 steel wheels?... Feb 7 2016, 12:22 PM
Bruce Hinds 215/60 x 15 phone dials, 6" up front and 7... Feb 7 2016, 12:17 PM
Larmo63 If you had the rear wheels widened, you could play... Feb 7 2016, 01:47 PM
bdstone914 How much wider is a 215 than a 205?
215-205 = 10M... Feb 7 2016, 10:54 PM
215-205 = 10... Feb 8 2016, 12:49 PM
blackmoon
215-205 = 10... Feb 9 2016, 11:19 AM
rhodyguy Pete, I thought you had taken the 185/70-15 path. ... Feb 8 2016, 07:15 AM
Mhead So, will the combo work?
...or is it too much ti... Feb 8 2016, 09:56 AM
Bruce Hinds
...or is it too much t... Feb 8 2016, 10:24 AM
rhodyguy there you go. smart move. sooner 1 crappy tire tha... Feb 8 2016, 12:55 PM
Mhead Thanks all...The idea of mounting one tire and try... Feb 8 2016, 08:02 PM
Bruce Hinds someone just posted a good idea for that. He spok... Feb 8 2016, 08:13 PM
rick 918-S Tire availability for anything in 14-15-16 is givi... Feb 9 2016, 08:50 AM
Racer
Tire availability for anything in 14-15-16 is giv... Feb 9 2016, 05:33 PM
horizontally-opposed Tire selections are getting have been tricky if yo... Feb 9 2016, 11:00 PM
horizontally-opposed Okay, so I found the pics I took during the 215/60... Feb 11 2016, 08:18 PM
horizontally-opposed Okay, so there was hope, or at least a little. The... Feb 11 2016, 08:25 PM
horizontally-opposed Sorry for a couple of sideways pics up above. Darn... Feb 11 2016, 08:29 PM
horizontally-opposed The Pirelli P6000 disappointment led to a new aven... Feb 11 2016, 08:31 PM
Larmo63 Pete, I have a set of 5mm spacers you can have for... Feb 11 2016, 08:32 PM
Larmo63 I'd venture to say that a set of 7R wheels wil... Feb 11 2016, 08:34 PM
horizontally-opposed Where I started back in 2006~: A set of old, hard ... Feb 11 2016, 08:34 PM
Larmo63 You might need a set of these too.
Feb 11 2016, 08:35 PM
At some po... Feb 15 2016, 10:56 AM
horizontally-opposed So the next stop was Vredestein Sprint Classics in... Feb 11 2016, 08:37 PM
horizontally-opposed So I wrote a column for some lousy magazine about ... Feb 11 2016, 08:40 PM
Larmo63 Somebody is tire obsessive. :driving: Feb 11 2016, 08:43 PM
Don't... Feb 11 2016, 08:54 PM
horizontally-opposed By 2012-2013, it was time for fresh tires. A lot o... Feb 11 2016, 08:45 PM
horizontally-opposed Lest you think I tried everything, I haven't. ... Feb 11 2016, 08:52 PM
Matty900
Porsche lists the 215/60R15 as an N1 tire approve... Feb 15 2016, 12:20 AM
[quote name='horizontally-opposed' post='206... Feb 15 2016, 10:49 AM![]() ![]() |
Lo-Fi Version | Time is now: 4th November 2026 - 07:28 AM |
