> Where do you find these gaskets?
cary
post Jul 20 2014, 08:52 AM
I pulled the engine to replace the oil pump cover .... drip, drip, drip.
But this gasket came apart when I pulled the heater tin.
It goes inside heater tin that attaches to blower housing. #24. Keeps moisture from getting inside the heating system I assume.
Dug thru both AA and Pelican and found nothing. Made an attempt at Bus Depot but I have no idea what its called or the part number. I know that I replaced them around 7-8 years ago.
type47
post Jul 20 2014, 09:35 AM
Viermeister
I think what you're looking for is called a "branch piece gasket" by AA. From the PET 202-15, no figure number as it doesn't seem to appear in the figure,
021.256.325 A gasket for cover and
021.256.326 A "
here is the part in AA: skip this link
http://www.autoatlanta.com/results.php
if the link doesn't show the part, search the AA catalog for 021.256.325A (and don't search for 021.256.325 A, notice the space before the "A")
and the link above doesn't get to the part. Try
http://www.autoatlanta.com/porsche-parts/h...;section=202-15
and scroll down, the gaskets are in the parts list after 18 and (18) ...
see also:
http://www.914world.com/bbs2/index.php?showtopic=215402
cary   Where do you find these gaskets?   Jul 20 2014, 08:52 AM
injunmort   try 914rubber, vendor on this site   Jul 20 2014, 09:26 AM
type47   I think what you're looking for is called a ...   Jul 20 2014, 09:35 AM
barefoot   My tins are missing these gaskets. Rather than pa...   Jul 20 2014, 09:55 AM
larryM   hardware store - std household door seals - glue ...   Jul 20 2014, 09:34 PM
bdstone914   hardware store - std household door seals - glue ...   Jul 21 2014, 12:49 PM
teenerteck   I don't think the heat will be an issue consid...   Jul 21 2014, 09:37 PM
cary   Here's the closest thing I've found. http:...   Jul 21 2014, 10:38 PM
rhodyguy   make an RTV bead where the gasket would lay on the...   Jul 22 2014, 08:14 AM
saigon71   I made some with thick cork gasket material from F...   Jul 23 2014, 06:34 AM
cary   Here's what I finally did. It's been curin...   Sep 21 2014, 09:45 AM
Bartlett 914   I used an O-ring I had around. It sealed both top ...   Sep 21 2014, 10:20 AM
pilothyer   I bought one of those red silicone flexible baking...   Sep 21 2014, 10:44 AM
Mikey914   Pretty easy to make. And pretty cheap too. If you ...   Sep 21 2014, 10:52 AM
bdstone914   Pretty easy to make. And pretty cheap too. If you...   Sep 21 2014, 10:59 AM
porsche913b_sp   Pretty easy to make. And pretty cheap too. If you...   Nov 18 2014, 10:52 PM
Larmo63   914s have heaters? :blink:   Sep 21 2014, 01:07 PM
bandjoey   anyone making these? couldn't find them on 91...   Nov 18 2014, 03:15 PM
rhodyguy   What crap! $33.85 for one side and ...   Nov 18 2014, 05:54 PM
mapguy   I would also be interested in a set, provided I ca...   Nov 18 2014, 11:30 PM
Mikey914   I need to make templates for these still. other th...   Nov 19 2014, 12:51 AM
walterolin   I need two sets. And I got my grill badges, the...   Nov 19 2014, 07:11 AM
BeatNavy   Yes, Mark, that would be swell to have these avail...   Nov 19 2014, 07:50 AM
cary   Mark do you need a couple for making patterns?   Nov 20 2014, 02:49 PM
- Lo-Fi Version Time is now: 7th December 2025 - 05:59 PM
