| cary |
Jul 20 2014, 08:52 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
I pulled the engine to replace the oil pump cover .... drip, drip, drip.
But this gasket came apart when I pulled the heater tin. ![]() ![]() It goes inside heater tin that attaches to blower housing. #24. Keeps moisture from getting inside the heating system I assume. ![]() Dug thru both AA and Pelican and found nothing. Made an attempt at Bus Depot but I have no idea what its called or the part number. I know that I replaced them around 7-8 years ago. |
| saigon71 |
Jul 23 2014, 06:34 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,019 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
I made some with thick cork gasket material from FLAPS and glued them in with RTV. It worked well.
cary Where do you find these gaskets? Jul 20 2014, 08:52 AM
injunmort try 914rubber, vendor on this site Jul 20 2014, 09:26 AM
type47 I think what you're looking for is called a ... Jul 20 2014, 09:35 AM
barefoot My tins are missing these gaskets. Rather than pa... Jul 20 2014, 09:55 AM
larryM hardware store - std household door seals - glue ... Jul 20 2014, 09:34 PM
bdstone914
hardware store - std household door seals - glue ... Jul 21 2014, 12:49 PM
teenerteck I don't think the heat will be an issue consid... Jul 21 2014, 09:37 PM
cary Here's the closest thing I've found.
http:... Jul 21 2014, 10:38 PM
rhodyguy make an RTV bead where the gasket would lay on the... Jul 22 2014, 08:14 AM
cary Here's what I finally did. It's been curin... Sep 21 2014, 09:45 AM
Bartlett 914 I used an O-ring I had around. It sealed both top ... Sep 21 2014, 10:20 AM
pilothyer I bought one of those red silicone flexible baking... Sep 21 2014, 10:44 AM
Mikey914 Pretty easy to make. And pretty cheap too. If you ... Sep 21 2014, 10:52 AM
bdstone914
Pretty easy to make. And pretty cheap too. If you... Sep 21 2014, 10:59 AM
porsche913b_sp
Pretty easy to make. And pretty cheap too. If you... Nov 18 2014, 10:52 PM
Larmo63 914s have heaters? :blink: Sep 21 2014, 01:07 PM
bandjoey anyone making these? couldn't find them on 91... Nov 18 2014, 03:15 PM
rhodyguy What crap! $33.85 for one side and ... Nov 18 2014, 05:54 PM
mapguy I would also be interested in a set, provided I ca... Nov 18 2014, 11:30 PM
Mikey914 I need to make templates for these still. other th... Nov 19 2014, 12:51 AM
walterolin I need two sets.
And I got my grill badges, the... Nov 19 2014, 07:11 AM
BeatNavy Yes, Mark, that would be swell to have these avail... Nov 19 2014, 07:50 AM
cary Mark do you need a couple for making patterns? Nov 20 2014, 02:49 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 05:58 PM |
