Trouble with Tie Rods... |
MikeM |
Jul 27 2014, 12:41 PM
Senior Member Group: Members Posts: 564 Joined: 16-May 10 From: Calgary, Canada Member No.: 11,733 Region Association: Canada |
Hi all...getting ready to install turbo tie rods and I'm trying to remove the old tie rods.
I have the outer end disconnected from the spindle and I'm trying to remove the tie rod and inner end together. This is easier said than done. Pelican article says to use the tie rod as a lever to loosen the inner end from the rack. Problem is that the worn inner bushing absorbs all the torque and the tie rod hits the body and has no where to go. What am I missing here?? Mike |
MikeM |
Jul 27 2014, 04:51 PM
I see what you are saying now!!! How the hell do people do this with the rack in the car?
Mike |
bdstone914 |
Jul 27 2014, 04:57 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I see what you are saying now!!! How the hell do people do this with the rack in the car? Mike I did one but it was on a lift. Since you are going with turbo tie rods you do not need to worry about damaging the round disk. Turn the tie rod end slightly counter clock wise as viewed from the end, then turn the disc clockwise to un jam the two parts. The toe rod will then un screw from the rack. |
MikeM |
Jul 27 2014, 09:32 PM
I see what you are saying now!!! How the hell do people do this with the rack in the car? Mike I did one but it was on a lift. Since you are going with turbo tie rods you do not need to worry about damaging the round disk. Turn the tie rod end slightly counter clock wise as viewed from the end, then turn the disc clockwise to un jam the two parts. The toe rod will then un screw from the rack. Thanks Bruce...that's really helpful. I take it I don't need that locking disc, but I do need the piece that the boot retainer attaches to? Correct? Mike |
Lo-Fi Version | Time is now: 10th June 2024 - 02:27 AM |
