Damaged front wheel bearing, How do you think this happened? |
malcolm2 |
Jul 27 2014, 04:18 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Trying to solve my DULL ROAR link is to my old, original post from a few weeks back.
and I found this bent outer wheel bearing, the small one: And the rear seal seems to be rubbing. Lot's of black dust here. These are TIMKIN, I had a set of FAG brand and put them on, but the ROAR remained during the test drive. Still curious how a bearing could get bent like this in about 4000 miles. Anyone know what I did wrong? |
Krieger |
Jul 28 2014, 09:01 AM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
When you put the screwdriver in to check washer movement, look where your at and try twisting it (as you normally use a screwdriver) against the hub itself. Use a larger screwdriver. Mine is 10mm wide at the tip.
Lo-Fi Version | Time is now: 2nd June 2024 - 04:39 PM |
