Aftermarket Parts Frustration, Update, Got it working |
914Sixer |
Jul 21 2014, 08:44 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I got some new parts in to make the turn signals and the horn work properly. Pulled the lower pad and took off the steering wheel. Took the 4 screws out and pulled the lower plugs and wiggled the washer hoses off. I got the combo out and separated them not breaking the joining clips.
Compared the German switch to the Meyle made in China. Every thing seemed ok. That is when I found out one of the posts was drilled ever so slightly off. Got the file out and went to work. Made every thing fit up. Re-installed combo and plugged up for a test. Switch was really stiff and I had to back screws off to free up lever. Pulled assembly back out to look at it. Put it back in again and it seemed to work better. Got it ready to test again. Took the steering wheel and removed the old cancel ring with the horn contact. Installed the new aftermarket one. Put wheel on and tested. The switch cancel worked to the right but not to the left. Said a few words of disgust. Pulled the wheel and looked again. Got the old cancel ring out and compared it to the new one. The new one appears to be about 2-3 mm shorter than the old ring. I quit for the evening. I will get on it tomorrow. (IMG:style_emoticons/default/headbang.gif) |
914Sixer |
Jul 29 2014, 08:56 PM
I had time this evening to figure things out. The 1st problem was the aftermarket horn cancel ring I got from Sierra Madre Collection. Depending on where you measure it at, the lip is between 1-2 mm shorter than the factory VW one. Second the horn clip is SO Cheap, it broke trying to put horn clip on. Repaired old VW canceling ring and reinstalled it in the wheel. Ready to test then.
Went back and looked at the aftermarket Meyle switch made in China. Did a little more filing and got it fit as flush as possible and aligned post. Put the switches together and noticed they did not line up. Base of the Meyle switch is different. Took a picture so you can see it DOES NOT clip in to base correctly. Took some tape and fitted them together in a semi-locked position. Slid it in and plugged everything up. Installed the wheel and checked to see if it was canceling. It did (IMG:style_emoticons/default/cheer.gif) . Then went down the list checking the electrical. Found bad turn signal relay. The relay clicked and turn signals flashed but the dash light did not. Installed new relay and everything worked (IMG:style_emoticons/default/cheer.gif) . Headlights flashed. (IMG:style_emoticons/default/biggrin.gif) No horn but I did not crawl under the front bumper (75). That will be for the next time. Attached image(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 09:41 PM |
