FS/Project 1973 914 Porsche 2.0 setup for LS Engine |
Don76 |
Jul 30 2014, 11:39 AM
Newbie Group: Members Posts: 3 Joined: 18-August 09 From: Los Angeles Member No.: 10,691 Region Association: Southern California |
FS: My Project 1973 914 Porsche 2.0 setup for LS Engine
1999 Camaro LS1 Engine 84,000 miles Runs Good 1989 911 Carrera complete 5 Lug front and rear suspension with Axles, Rotors, Calipers 4 Fuchs Wheels and New Tires 2-16x8 225/50-16, 2-16x7 205/55-16 Renegade Hybrids Basic LS-Series Conversion Kit: Renegade Custom Motor Mount Assembly Custom Rear Transaxle Set Back Blocks Billet Aluminum Adapter Plate One Piece Billet Flywheel and Starter Ring Gear Stage Two High Performance Nine Inch Pressure Plate Kevlar High Performance Nine Inch Clutch Disc Custom Pilot Bearing Throw Out Bearing Water Pump and Fittings Billet Aluminum Coolant Inlet/Outlet Plates and Fittings Custom Aluminum Filler Neck In Line Filler "T" Coolant Outlet "Log" Custom Alternator Bracket Gates Green Stripe Hose Alternator Belt All necessary hardware Renegade Hybrids 914 Complete Cooling System: With custom all aluminum radiator, dual high performance Spal fans, dual relays, thermostatic control switch, harness and all necessary sheet metal. LS-Series to 914 Complete Custom Fuel Injection Harness by Renegade Hybrids LS- Series Computer Programming by Renegade Hybrids Radiator Hose Kit by Renegade Hybrids Custom Front Valance by Renegade Hybrids 914 Rear GT Spoiler by American International Racing 914 Front and Rear Trunk shox kit by Camp 914 Rear Axle Joint Flange Adapter Set Porsche 901 / 914 Transmission to larger 911 Carrera Axle Assembly by Patrick Motorsports Wheel Bearing Rear Porsche Carrera by Patrick Motorsports Rear Axle Control Arm Box Reinforcement Set by Patrick Motorsports Axle Spacer Inner And Outer 914 / 901 To Carrera Drive Axle Assembly This Item Is Designed For Use With 5 Lug Carrera Axle Flange by Patrick Motorsports 914 Chassis Reinforcement Stiffening Kit: LS1 Headers: $8000.00 takes it all All the above items will not be sold separate Car is located in Los Angeles local pick-up no shipping Call Donnie for more info 323-547-7806 Will consider some trade need a Chevy Vortec 8100 L18 Engine with Transmission, wiring harness and computer Attached image(s) |
motomoss |
Jul 31 2014, 05:29 AM
Newbie Group: Members Posts: 4 Joined: 1-July 12 From: New Buffalo MI Member No.: 14,620 Region Association: None |
do you still have the 2.0 which was originally in the car and are you interested in selling.
Lo-Fi Version | Time is now: 23rd May 2024 - 12:29 PM |
