What pistons? |
What pistons? |
shandyhaggis |
Jul 31 2014, 05:17 AM
Newbie Group: Members Posts: 49 Joined: 2-February 11 From: UK Member No.: 12,653 Region Association: None |
Hi all
Im restoring a US 1976 2.0 with a 1973 2.0 engine (not sure how that happened but hey). Im in the UK and these are as rare as hens teeth. Ive decided to retrofit a standard FI system (currently gathering the relevant bits). My engine builder has suggested a Web cam - WEB #73 262/262 duration 0.426 lift which I believe is correct. Any ideas on what pistons I should use? The 73 engine has bus pistons which are in good shape but if Im going to the expense of rebuilding then I feel I should put something better back in. Im not looking to build a hot rod just a nice reliable fun motor. My engine chap is suggesting Keith and Black pistons (96mm). Would that work or are there better options? thanks Andrew |
cary |
Jul 31 2014, 07:09 AM
Advanced Member Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest |
Here's the guys to talk to if you want the better options.
http://type4store.com/products/piston-cylinder-rings.html Here's the other option. http://www.europeanmotorworks.com/vw/type-...-cylinders.html Haven't used either for hard parts. But its where I'd go if I needed pistons and cylinders. My .02c. |
shandyhaggis |
Jul 31 2014, 09:47 AM
Here's the guys to talk to if you want the better options. http://type4store.com/products/piston-cylinder-rings.html Here's the other option. http://www.europeanmotorworks.com/vw/type-...-cylinders.html Haven't used either for hard parts. But its where I'd go if I needed pistons and cylinders. My .02c. thanks for that, Ill follow up. Andrew |
Lo-Fi Version | Time is now: 1st June 2024 - 08:30 AM |
