Exhaust stud removal |
SKL1 |
Aug 1 2014, 05:30 PM
Senior Member Group: Members Posts: 1,607 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Putting in the header pipes this afternoon- driver's side goes right in no issues. Discover one of the studs on passenger side is stripped. Of course I didn't realize this when rebuilding the engine.
Any ideas on how to back the stud out of the head? Not a lot of room in there to work... TIA- search function didn't help much... Found a Lisle stud removal tool but don't think there is enough room to fit it in there. Trying to think what would fit that would grip the stud tight enough to twist it out. When removing the nuts a few years ago in the beginning of the restoration (yes, it's taking that long) a couple studs came out with the nut- wish that would have happened here!! |
Cap'n Krusty |
Aug 1 2014, 06:46 PM
Weld a nut on it, and be sure you have good penetration! I've never seen an extractor that will work on a T4 head. Once you've done that, apply heat to the base and go for it. Tighten a bit, loosen a bit, go back and forth til' you get it. Heat the head, not the stud, as much as possible.
The Cap'n |
Lo-Fi Version | Time is now: 10th June 2024 - 11:56 PM |
