> Starting issues with my suby conversion! Fuch fire, Opened my garage tonight to a smokey smell
JRust
post Aug 1 2014, 09:29 PM
Okay I have a 73 with a 2.5 SOHC subaru conversion. It has a Stinger 4420 ECU. When I bought it sometimes when I got in it didn't want to start. It would turn over with no problem but no start. Not getting spark. I called Dean who built the car to see if it was something he had run into. It was the ignition switch & he said it seemed to go through one of those cheap switches about every 6-8 months. So I replace the switch as soon as I put the new switch in I get a puff of smoke from the new switch. It still worked fine after so didn't think much about it. So it works for a month or so & I get the same issue. Kind of off & on it doesn't want to start. By switching the key on a couple times. It would start but only for a bit as it would get progressively worse. I thought it was the starter was pulling to much through the switch. So I added a push button starter & took the wire off the key totally. Started great for a while but I am having the same issue again. So this time when it didn't start I went to my coil. Pulled the feed wires & checked the connection. All looked good. Plugged it back in & my car started right up (IMG:style_emoticons/default/idea.gif) . Well next day same deal no start (IMG:style_emoticons/default/WTF.gif) . Try it again unplugging the coil & same result. It works again for the last few weeks with no problem. I make a run into town for some of my a/c parts. As I pull out of the auto zone my car dies. Won't start again so I push it back into the lot. I flat tow it home & ask my mechanic to come over. He is thinking it's the Cam or cranks sensors. Both check out. I thought maybe I may have a bad coil. So I picked up one to rule that out. That made no difference. I think it is still tied to the key ignition but a new switch made no difference. I've checked grounds & they all seem clean & fine. I've reseated any wire remotely tied to it. It really seems like the key ignition is the problem. The feed to the computer I am thinking must be pulling to much & blowing my switches. I don't know (IMG:style_emoticons/default/WTF.gif)
(IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif)
Suggestions & please don't give me go air cooled shit okay. I love my suby setup I just need to figure out what this problem is
904svo
post Aug 1 2014, 10:21 PM
904SVO
Sounds like your ignition switch is supplying all the power thru it.
SUBARU has installed lots of power relays which are control by the ignition switch
Main relay powers engine and 02 sensors
fuel pump relay
ETC relay (Electronic throttle)
I would check and see if you have power relays.
JRust   Starting issues with my suby conversion! Fuch fire   Aug 1 2014, 09:29 PM
904svo   Sounds like your ignition switch is supplying all ...   Aug 1 2014, 10:21 PM
Elliot Cannon   Your car is cursed. Japanese engines are NOT comp...   Aug 1 2014, 10:25 PM
mgp4591   Your car is cursed. Japanese engines are NOT com...   Aug 1 2014, 11:00 PM
Porschef   Your car is cursed. Japanese engines are NOT co...   Aug 2 2014, 02:42 PM
mgp4591   [quote name='mgp4591' post='2068861' date='Aug 2 ...   Aug 5 2014, 04:47 PM
Mike Bellis   Find the ignition relay and replace it. Corrosion ...   Aug 1 2014, 10:59 PM
Mike Bellis   BTW, check all the grounds and wire connections to...   Aug 1 2014, 11:01 PM
edwin   one of the greatest things about aftermarket ecu...   Aug 2 2014, 01:53 AM
JRust   one of the greatest things about aftermarket ecu...   Aug 2 2014, 02:04 AM
Mike Bellis   You need to figure out what you have and label it....   Aug 2 2014, 07:14 AM
JRust   Mike I am not getting power to the coil. So to rul...   Aug 2 2014, 09:10 AM
BIGKAT_83   Outfront motorsports have the stinger manuals and ...   Aug 2 2014, 09:37 AM
JRust   Outfront motorsports have the stinger manuals and...   Aug 2 2014, 10:18 AM
BIGKAT_83   So what was the problem???? :shades2:   Aug 5 2014, 10:42 AM
JRust   I haven't figured it out Bob. I've checked...   Aug 5 2014, 10:52 AM
BIGKAT_83   This will HELP. :popcorn:   Aug 5 2014, 02:00 PM
76-914   Damnit that Stinger wiring looks simple. Maybe I c...   Aug 5 2014, 03:07 PM
Chris H.   Damnit that Stinger wiring looks simple. Maybe I ...   Aug 5 2014, 06:26 PM
JRust   I am running the stock Subaru coil. So there is ba...   Aug 5 2014, 07:27 PM
BIGKAT_83   Your running a wasted spark system with a external...   Aug 5 2014, 08:03 PM
- Lo-Fi Version Time is now: 7th July 2025 - 05:54 AM
