| Mueller |
Aug 16 2004, 06:56 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
I'm having "issues" with my 1.8 injectors currently on my normally asperated 1.8 (rebuilt, but odd spray patterns)
I'd like to replace the injectors with good injectors with known flow rates......once I add bolt on the turbocharger, the stock 1.8 injectors will not have enough flow for my needs so I figured I might as well kill two birds with one stone (IMG:style_emoticons/default/smile.gif) Are new 2.0 injectors available and if so, what should I expect to pay for them? What about getting used 2.0 injectors and sending them to a fuel injection specialist?? Cost of service I should expect to pay?? thanks |
| fiid |
Aug 17 2004, 03:33 PM
Turbo Megasquirted Subaru Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,828 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
Since you are running a megasquirt - you have the option of running just about any high impedance injector with no problems what-so-ever. You may also consider a set of pick-n-pull injectors off of any Subaru - and you shouldn't have too much of a problem looking up the flow rate. As an alternative - you could order a new set of injectors from a subaru motor.
Fiid. |
Mueller 2.0 injectors...new or rebuilt??? Costs?? Aug 16 2004, 06:56 PM
Kerrys914 I don't have the name hear at work but a searc... Aug 17 2004, 11:05 AM
MarkG I sent my 2.0 injectors and TB to EBS Racing last ... Aug 17 2004, 03:45 PM
Brad Roberts We need to find out who EBS is using to clean the ... Aug 17 2004, 05:04 PM
Mueller no idea who rebuilt the 1.8 injectors, they came i... Aug 17 2004, 05:36 PM
lapuwali Mike, I think one problem with running 2.0 injecto... Aug 17 2004, 05:39 PM
TimT Mike, Bradholio
check:
RC engineering
or
Marr... Aug 17 2004, 05:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:31 AM |
