| Mueller |
Aug 16 2004, 06:56 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
I'm having "issues" with my 1.8 injectors currently on my normally asperated 1.8 (rebuilt, but odd spray patterns)
I'd like to replace the injectors with good injectors with known flow rates......once I add bolt on the turbocharger, the stock 1.8 injectors will not have enough flow for my needs so I figured I might as well kill two birds with one stone (IMG:style_emoticons/default/smile.gif) Are new 2.0 injectors available and if so, what should I expect to pay for them? What about getting used 2.0 injectors and sending them to a fuel injection specialist?? Cost of service I should expect to pay?? thanks |
| lapuwali |
Aug 17 2004, 05:39 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Mike, I think one problem with running 2.0 injectors on the 1.8 BEFORE you fit the turbo will be getting MS to handle the necessarily tiny pulsewidths at idle. The 2.0 injectors are so large the idle pulsewidths are very near (or even below) the stock MS resolution, making a good idle very hard to achieve. You may have to use the "high resolution" MS code rather than the off-the-shelf code. This may, in fact, even be true w/ the turbo, since you're idling off-boost, and will still need basically the same pulsewidths.
Mueller 2.0 injectors...new or rebuilt??? Costs?? Aug 16 2004, 06:56 PM
Kerrys914 I don't have the name hear at work but a searc... Aug 17 2004, 11:05 AM
fiid Since you are running a megasquirt - you have the ... Aug 17 2004, 03:33 PM
MarkG I sent my 2.0 injectors and TB to EBS Racing last ... Aug 17 2004, 03:45 PM
Brad Roberts We need to find out who EBS is using to clean the ... Aug 17 2004, 05:04 PM
Mueller no idea who rebuilt the 1.8 injectors, they came i... Aug 17 2004, 05:36 PM
TimT Mike, Bradholio
check:
RC engineering
or
Marr... Aug 17 2004, 05:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 10:36 AM |
