yeahmag |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,456 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California ![]() ![]() |
Thanks to Bruce Stone I have some sheet metal to work with. My plan is as follows:
* Plan A: Use a Port-a-power to push as much of the metal back in to shape and hammer and dolly from there. I have at least one line on an affordable body shop to do the finish work after I rough it in. * Plan B: Push some metal back and cut and weld in parts from the lot that Bruce secured for me. * Plan C: Push the fronts back in as close as I can get and flare the rear with QRS panels and Duz fastners. ![]() |
914_teener |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,266 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California ![]() |
It looks really good Aaron.
If you are going to grind down those welds.... I don't recommend Evidure for any structural stuff. It is great for bonding body panels and such. It doesn't have the same shear strength and will crack over time. |
Lo-Fi Version | Time is now: 1st August 2025 - 02:27 PM |
