> Streets of Willow off rebuild, started pushing out the dents
yeahmag
post Apr 22 2014, 03:07 PM
Thanks to Bruce Stone I have some sheet metal to work with. My plan is as follows:
* Plan A:
Use a Port-a-power to push as much of the metal back in to shape and hammer and dolly from there. I have at least one line on an affordable body shop to do the finish work after I rough it in.
* Plan B:
Push some metal back and cut and weld in parts from the lot that Bruce secured for me.
* Plan C:
Push the fronts back in as close as I can get and flare the rear with QRS panels and Duz fastners.
914_teener
post Aug 4 2014, 05:14 PM
Sorry....I'm getting old.
I think it is spelled Everdur....Silicon Bronze welding wire. That is what I used to call it.
It flows really nice and you'll get lower weld distortion on the body panels, since there is lower heat input.
Any structural stuff like longs and the such, I'd use regular welding wire for that purpose.
yeahmag   Streets of Willow off rebuild   Apr 22 2014, 03:07 PM
yeahmag   Here's pictures of the damage again:   Apr 22 2014, 03:09 PM
yeahmag   RE: Streets of Willow off rebuild   Apr 22 2014, 03:10 PM
Dr Evil   For race only, I like the detachable fenders with ...   Apr 22 2014, 06:17 PM
yeahmag   Started work pushing the dents out using a port-a-...   May 7 2014, 12:30 PM
yeahmag   RE: Streets of Willow off rebuild   May 7 2014, 12:31 PM
396   Looking good. Good luck with the repairs   May 8 2014, 12:16 PM
Chris H.   Wow your door gaps look great compared to where th...   May 8 2014, 12:24 PM
Jmkorfha   Looking good. And familiar. I didn't have the ...   May 8 2014, 02:45 PM
yeahmag   Here is the front fender after some hammer and dol...   May 19 2014, 05:36 PM
yeahmag   RE: Streets of Willow off rebuild   May 19 2014, 05:37 PM
yeahmag   I think the rear quarter is a goner though. I...   May 19 2014, 05:38 PM
Elliot Cannon   You shoulda gone with plan C. :D Is that my old ...   May 19 2014, 10:54 PM
yeahmag   Don't tempt me Elliot! That extra $40...   May 20 2014, 04:55 PM
yeahmag   Spare panel is cleaned and ready. Starting work on...   Jun 8 2014, 04:57 PM
yeahmag   Just some loose cuts to help start fitting the new...   Jun 8 2014, 04:58 PM
r_towle   If your friend has an English wheel.....see if he ...   Jun 8 2014, 05:33 PM
yeahmag   He does, but I'm only doing one fender, so I m...   Jun 8 2014, 06:23 PM
yeahmag   Test fitting has begun.   Jun 17 2014, 10:57 AM
yeahmag   A few more pictures of us fitting the replacement ...   Jun 27 2014, 03:24 PM
yeahmag   RE: Streets of Willow off rebuild   Jun 27 2014, 03:24 PM
yeahmag   RE: Streets of Willow off rebuild   Jun 27 2014, 03:25 PM
Socalandy   Nice work!!!   Jun 27 2014, 03:34 PM
rick 918-S   Looks like its working out fine! :sawzall: :s...   Jun 28 2014, 02:57 AM
yeahmag   Trial fitting is over and we have started welding....   Aug 4 2014, 03:56 PM
yeahmag   RE: Streets of Willow off rebuild   Aug 4 2014, 03:57 PM
yeahmag   RE: Streets of Willow off rebuild   Aug 4 2014, 03:58 PM
yeahmag   Starting to work on the tail light/bumper sections...   Aug 4 2014, 04:17 PM
914_teener   It looks really good Aaron. If you are going to g...   Aug 4 2014, 05:00 PM
yeahmag   Never heard of Evidure... I am going to grind th...   Aug 4 2014, 05:05 PM
914_teener   Sorry....I'm getting old. I think it is spell...   Aug 4 2014, 05:14 PM
yeahmag   Ah... I've had really good luck with the stuff...   Aug 4 2014, 05:19 PM
yeahmag   Turns out I had a cracked/torn stub pipe too. Used...   Oct 27 2014, 07:38 PM
yeahmag   And here is what I found.   Oct 27 2014, 07:39 PM
yeahmag   I drilled the ends of the crack/tear to relieve an...   Oct 27 2014, 07:42 PM
Philip W.   any updated pictures of the welding/ paint progres...   Oct 28 2014, 08:42 AM
yeahmag   Nothing new there. I plan to weld in the longitudi...   Oct 28 2014, 03:25 PM
yeahmag   Finally got some time yesterday to make some headw...   Feb 2 2015, 03:38 PM
yeahmag   After sanding I laid down a guide coat. I've g...   Feb 2 2015, 03:39 PM
yeahmag   Closer still... Going to use some 2 part glazing t...   Jun 15 2015, 12:41 PM
- Lo-Fi Version Time is now: 1st August 2025 - 02:24 PM
