Headlight bulbs-SOLVED!, How to test |
HalfMoon |
Aug 1 2014, 09:48 PM
Senior Member Group: Members Posts: 828 Joined: 13-November 12 From: Shenandoah Junction, WV Member No.: 15,144 Region Association: MidAtlantic Region |
Lost my right side headlight high beam. I have another headlight bulb lying around (from PO) but have no idea if it's good or not. Since it's a bit of a bith to change bulbs on our little 914's on a maybe, I thought I'd ask if anyone knows how to test a unmounted headlight bulb. I have an ohm meter and I also have a continuity tester.
Thanks in advance David |
Mike Bellis |
Aug 4 2014, 10:11 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
If one light works, it's not the switch or the Hi/Lo relay. Spin the fuse in the fuse holder . If the other lamp will light, there is power at one side of the fuse. The wire goes directly from the fuse to the lamp.
Lo-Fi Version | Time is now: 1st June 2024 - 02:56 AM |
