> Tapered Fuel Hose, No longer availabe at Pelican Parts
JawjaPorsche
post Jan 16 2012, 04:55 PM
I see where the Tapered Fuel Hose is no longer available at Pelican Parts:
http://www.pelicanparts.com/cgi-bin/smart/...74%29%2C%20Each
Does anyone know an alternative source?
Also dumb question. The description says "Tapered Fuel Hose For Connection at Fuel Filter."
I thought the hose was also used for the outlet port on the fuel pump because the connection is smaller than the standard hose size: 8 mm?
pete000
post Aug 5 2014, 02:16 PM
Glad I got one a few years back when I started my fuel line replacement project. Car is still in the air and the lines all in boxes in my garage, good grief I need to get my car going again !
I bet AA has them at a new adjusted price !
Phoenix914
post Aug 5 2014, 02:39 PM
QUOTE(pete000 @ Aug 5 2014, 04:16 PM) *
I have the same problem! That's why I'm looking for things like this fuel hose - trying to gather parts for a comprehensive tune up and refresh in hopes of getting on the road again.
And even AA has this part listed as "discontinued."
bdstone914
post Aug 5 2014, 06:58 PM
bdstone914
QUOTE(Phoenix914 @ Aug 5 2014, 01:39 PM) *
I made one out of a piece of hose that was the correct size for the small end. I clamped a tapered punch in the vise and shoved the hose onto the punch after soaking the hose in boiling water. It stretched the hose enough to work.
JawjaPorsche   Tapered Fuel Hose   Jan 16 2012, 04:55 PM
billh1963   I thought it was only for the fuel tank line comin...   Jan 16 2012, 05:12 PM
wingnut86   Check Automation and Vertex. They used to carry t...   Jan 16 2012, 05:50 PM
type47   Chris Foley sells a stainless steel piece that doe...   Jan 16 2012, 06:12 PM
Racer Chris   Chris Foley sells a stainless steel piece that do...   Jan 16 2012, 06:42 PM
SLITS   Gad, go to ACE Hardware or a place like that and g...   Jan 16 2012, 06:47 PM
Cap'n Krusty   Gad, go to ACE Hardware or a place like that and ...   Jan 16 2012, 08:19 PM
SLITS   Gad, go to ACE Hardware or a place like that and...   Jan 17 2012, 10:23 AM
dangrouche   I employ Chris' taper stainless adaptor tubing...   Jan 16 2012, 07:46 PM
rick 918-S   I employ Chris' taper stainless adaptor tubin...   Jan 17 2012, 12:03 AM
ClayPerrine   If IIRC, there is a Mercedes Diesel hose that wor...   Jan 17 2012, 10:30 AM
Phoenix914   If IIRC, there is a Mercedes Diesel hose that wo...   Aug 5 2014, 11:12 AM
Dave_Darling   Your hardware store will have hose barbs and fitti...   Aug 5 2014, 01:27 PM
Phoenix914   Thanks Dave. I'll probably go that route. Th...   Aug 5 2014, 01:34 PM
pete000   Glad I got one a few years back when I started my ...   Aug 5 2014, 02:16 PM
Phoenix914   good grief I need to get my car going again ...   Aug 5 2014, 02:39 PM
bdstone914   good grief I need to get my car going again ...   Aug 5 2014, 06:58 PM
Phoenix914   I made one out of a piece of hose that was the co...   Aug 5 2014, 07:24 PM
Racer Chris   Trying to find that tapered hose is a waste of tim...   Aug 5 2014, 03:14 PM
mepstein   I bought mine from Chris - Tangerine. He has all t...   Aug 5 2014, 08:06 PM
pete000   I noticed Sierra Madre lists them as NLA now too.....   Aug 6 2014, 11:18 PM
Phoenix914   That looks like a nice piece, and cheaper than a M...   Aug 7 2014, 05:09 AM
Racer Chris   That Jegs piece is perfect.   Aug 7 2014, 06:16 AM
Phoenix914   That Jegs piece is perfect. Looks like it might...   Aug 7 2014, 06:22 AM
Racer Chris   That Jegs piece is perfect. Looks like it migh...   Aug 7 2014, 07:45 AM
stinkindiesel   Has anybody identified a suitable fuel filter with...   Aug 19 2014, 03:45 PM
Kansas 914   Has anybody identified a suitable fuel filter wit...   Aug 19 2014, 07:51 PM
stinkindiesel   I used to buy mine from Brad at 914ltd.com. He do...   Aug 20 2014, 07:47 AM
Racer Chris   Yep, the WIX 33274 is the correct one that has th...   Aug 20 2014, 08:30 AM
stinkindiesel   Yep, the WIX 33274 is the correct one that has t...   Aug 20 2014, 12:22 PM
Dave_Darling   Has anybody identified a suitable fuel filter wit...   Aug 19 2014, 09:09 PM
pete000   Fram makes an all metal filter with the 3/8 (10mm)...   Aug 19 2014, 09:07 PM
mapguy   Awesome! That Wix unit is just the ticket...   Aug 19 2014, 11:01 PM
bandjoey   Bought one like the wix. Don't remember the br...   Aug 20 2014, 07:55 AM
Phoenix914   Has anybody used this WIX filter? The description...   Nov 18 2014, 10:06 AM
Racer Chris   Has anybody used this WIX filter? The descriptio...   Nov 18 2014, 11:25 AM
Phoenix914   Wix 33002 is a better choice. 8mm inlet and outl...   Nov 18 2014, 01:15 PM
dcheek   VW uses a similar hose. I ordered one for one of m...   Nov 18 2014, 02:34 PM
Mikey914   I personally don't like Wix. I had a problem w...   Nov 18 2014, 11:59 PM
dcheek   This is the one I used on my Rabbit a while back. ...   Nov 19 2014, 03:27 PM
Phoenix914   This listing says the hose is 7/11 mm. :idea: ...   Nov 19 2014, 04:10 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:36 AM
