Dellorto Carbs, How to sync and get the most out of them. |
kixx |
Jul 28 2014, 11:31 AM
Newbie Group: Members Posts: 11 Joined: 6-July 11 From: AR Member No.: 13,283 Region Association: None |
Hello All, I have worked on carbs before but have never had to sync them, I have looked on here and have not found the sync ing carbs for dummies guide yet. I am at a loss on where to find info for the dell carbs to get started. The car does start and run as well as idles fair, really seems to just bottom out (lacks power) when i try to get it up to speed. Any and all help is very much appreciated, also i will be needing a temp sensor and a set of air filters for them, any good shop references ??? Thanks, Best Regards
rhodyguy |
Aug 6 2014, 02:27 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,084 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
where's the pump picture? you need to ditch the 'old school' fuel line, ALL of it, for modern fuel line and get at least one shouldered fuel line clamp. your linkage has prob seen better days. i can't make out the DRLA # in the picture. use some pbblaster on the carb fasteners and linkage connection points before you start wrenching on them.
kixx |
Aug 6 2014, 02:49 PM
where's the pump picture? you need to ditch the 'old school' fuel line, ALL of it, for modern fuel line and get at least one shouldered fuel line clamp. your linkage has prob seen better days. i can't make out the DRLA # in the picture. use some pbblaster on the carb fasteners and linkage connection points before you start wrenching on them. looks like 45s, you know about them? pbblaster ??(penetrate oil) |
Lo-Fi Version | Time is now: 1st June 2024 - 02:09 AM |
