Dellorto Carbs, How to sync and get the most out of them. |
kixx |
Jul 28 2014, 11:31 AM
Newbie Group: Members Posts: 11 Joined: 6-July 11 From: AR Member No.: 13,283 Region Association: None |
Hello All, I have worked on carbs before but have never had to sync them, I have looked on here and have not found the sync ing carbs for dummies guide yet. I am at a loss on where to find info for the dell carbs to get started. The car does start and run as well as idles fair, really seems to just bottom out (lacks power) when i try to get it up to speed. Any and all help is very much appreciated, also i will be needing a temp sensor and a set of air filters for them, any good shop references ??? Thanks, Best Regards
yeahmag |
Aug 6 2014, 02:47 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
You may want to sell those. I ran 45's on a full tilt drag motor (VW). They will never behave the way you want unless that is a large displacement, huge cam, high rev motor. You'll get enough for them to buy yourself a set of 36's or 40's and then some.
kixx |
Aug 6 2014, 02:51 PM
You may want to sell those. I ran 45's on a full tilt drag motor (VW). They will never behave the way you want unless that is a large displacement, huge cam, high rev motor. You'll get enough for them to buy yourself a set of 36's or 40's and then some. i have a set of weber 1 barrels on the 75 Attached thumbnail(s) |
Lo-Fi Version | Time is now: 6th June 2024 - 12:20 PM |
