Intake tube differences? |
monkeyboy |
Aug 6 2014, 11:02 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I am trying to put the FI back on my engine and I have gotten to the point where I am mocking up manifolds and plenum.
Here is what I know. I have a bigger 2.0 plenum, I have a motor that I was told is a 2.0 that has been rebuilt. I have 4 bolt intake tubes, but they hit the engine tin, and look like they are too long for the plenum. I am guessing those are for a 1.7. Not sure. What intake tubes do I need. Are they 2.0 only, or did the 1.8 use the same plenum as the 2.0? |
TheCabinetmaker |
Aug 7 2014, 05:54 AM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
He might have a 2.0L Mike. 2L bus heads have 4 bolt intake.
What's the #on the case? |
Dave_Darling |
Aug 7 2014, 08:24 AM
He might have a 2.0L Mike. 2L bus heads have 4 bolt intake. But the Bus 2.0 did not use the 914 intake manifolding, so that doesn't really matter. If you want to use the 2.0 plenum, you can either get 2.0 intake runner pipes and re-drill the mounting holes, or you can get some 1.8 intake runner pipes and cut them off shorter so they fit with the 2.0 plenum. The 1.7 pipes are a smaller diameter than the others. --DD |
monkeyboy |
Aug 7 2014, 08:44 AM
He might have a 2.0L Mike. 2L bus heads have 4 bolt intake. But the Bus 2.0 did not use the 914 intake manifolding, so that doesn't really matter. If you want to use the 2.0 plenum, you can either get 2.0 intake runner pipes and re-drill the mounting holes, or you can get some 1.8 intake runner pipes and cut them off shorter so they fit with the 2.0 plenum. The 1.7 pipes are a smaller diameter than the others. --DD Perfect. Thank you. The case is an EC case. I know it's not original to the car. It has been blown up earlier in it's life. The heads are stamped from GEX as well. The motor had been purchased in the mid 80's and left next to the car where it was when I bought it all. It had no induction on it. Since the car was originally a 1.7 this may be why the project never got any farther. |
Lo-Fi Version | Time is now: 1st June 2024 - 04:50 PM |
