FS Tachometer, Converted for a 6 |
Timmyjr11 |
Jul 25 2014, 08:48 PM
Newbie Group: Members Posts: 4 Joined: 30-March 14 From: Indiana Member No.: 17,179 Region Association: None |
My dad and I worked on this gauge together. It is a standard tachometer for the 914, but has been modified with modern servo tach drive. This tachometer has been calibrated for a six cylinder.
This tachometer will work with all signal inputs, so no tach converter is necessary. For the people that put a six cylinder in your 914, this is the tachometer for you! Asking $350, which will help my funds for buying a 914 before I turn 16 (IMG:style_emoticons/default/driving.gif) |
rnellums |
Aug 9 2014, 08:26 AM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
The workmanship looks phenomenal! (IMG:style_emoticons/default/drooley.gif) I just installed a 6-cyl Subaru engine and need a clean Tach solution. I wonder if I could use the same wire that feeds the ECU engine speed (IMG:style_emoticons/default/idea.gif) Are the spade connectors on the back hooked up the same? (+12, signal, grnd). Beautiful work!
(Also, I got my first 914 at 14 and restoring it was quite the journey!) Attached image(s) |
Lo-Fi Version | Time is now: 4th June 2024 - 09:32 AM |
