| Larmo63 |
Aug 9 2014, 03:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I know the cars come pre-wired, I now have stock fogs installed on my '73 1.7L, and have a few questions. Should the wires on the front be wired all the way into to foglight bodies? What the factory left is still there, including the rubber grommets so do they wire right through, or should I make connections with the wires coming out of my lights? (does that make sense?) Are all of the correct wires just ready for plug in above the fuse box? My car hasn't been fiddled with, so I have no doubt they will still be there. I bought the bypass wiring kit on eBay so that the fogs will work on the flasher and independently of the headlight switch. Anybody here have comments on that mod? Thanks ahead of time! (IMG:style_emoticons/default/confused24.gif)
| Larmo63 |
Aug 10 2014, 03:27 PM
1973 914: What wires am I looking for coming out of the wiring harness under the dash and where/what do they hook up to? The front wiring was pretty straightforward and obvious.
Wire colors? Wire locations? I don't have the extra mod yet , but I'd to have the fogs come on by the foglight switch only for now. Sorry for all the silly questions. Before I tear into it, I'd like this to be clear. I'm printing out the wiring diagram as we speak, but any help, helps! |
| worn |
Aug 10 2014, 04:51 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
1973 914: What wires am I looking for coming out of the wiring harness under the dash and where/what do they hook up to? The front wiring was pretty straightforward and obvious. Wire colors? Wire locations? I don't have the extra mod yet , but I'd to have the fogs come on by the foglight switch only for now. Sorry for all the silly questions. Before I tear into it, I'd like this to be clear. I'm printing out the wiring diagram as we speak, but any help, helps! In my '76 I found the appropriate colored wires and a hole for the switch under the dash. I just plugged them into the switch. Up front I goofed and accidentally wired my new lights to wiring provided for an optional second horn. But then I found the correct wires, and again no crimps, just plug. I did have to cut into the rubber bumper to mount the lights though. I also found that since the headlight relay will not work with the key off, I wanted the fog lights to be the same, but on when the lights are off. I found a fuse that was key switched and used this to go to the switch activating the fog light relay, moving the wires from the headlight and over to the switched fuse. Then if the key is on the fog lights come on when I pull the green switch. If I forget to turn them off, they turn themselves on when I turn off the motor. You actually got both information and attitude. This is by far the most well moderator community I live with. Might hold off on making a judgement till a couple of questions in. These guys have gone the extra mile for me time after time, and they know. (IMG:style_emoticons/default/driving.gif) |
Larmo63 How hard are 914 fogs to wire? Aug 9 2014, 03:04 PM
SirAndy Lets start with the obvious, what year is your car... Aug 9 2014, 03:13 PM
Black22
I know the cars come pre-wired, I now have stock ... Aug 9 2014, 03:14 PM
Larmo63 Delete. Aug 9 2014, 03:18 PM
Black22
Sorry, the car is a '73 and I do have the swi... Aug 9 2014, 06:58 PM
Philip W. My 75 had the wiring already in the trunk, but the... Aug 9 2014, 05:10 PM
Porschef I added fogs along with the bumper backdate on my ... Aug 9 2014, 05:16 PM
toolguy Keep in mind, if you use factory wiring, Fog light... Aug 9 2014, 07:22 PM
Hank914
Keep in mind, if you use factory wiring, Fog ligh... Aug 9 2014, 11:29 PM
smveril I am reinstalling my driving lights on my 73.
The... Aug 10 2014, 06:42 AM
SirAndy Haynes manual or for color diagrams, go here:
htt... Aug 10 2014, 04:11 PM
Larmo63 Delete. Aug 10 2014, 04:34 PM
SirAndy I get it, I won't ask again.
Jeeze, seriously?... Aug 10 2014, 11:21 PM
screenguy914 I just modified my fog light circuit in my recentl... Mar 18 2015, 06:26 PM
Cuda911 Very basic question here:
I've never pulled ... Mar 18 2015, 11:02 PM
Larmo63 Wiring is present behind the grilles. The switches... Mar 19 2015, 08:56 AM
Cuda911
Wiring is present behind the grilles. The switche... Mar 19 2015, 10:59 PM
Dave_Darling
Can I assume the wiring's there?
Is there a b... Mar 19 2015, 09:00 AM
Cuda911 Thanks, guys.
Any of you out there with some fog... Mar 19 2015, 04:39 PM
Larmo63 Bruce Stone should have something. I know somebody... Mar 19 2015, 07:57 PM
Larmo63 http://www.914world.com/bbs2/index.php?showtopic=2... Mar 19 2015, 08:27 PM
Cuda911 Thanks, I sent him a PM. Mar 19 2015, 08:48 PM
Larmo63 http://www.914world.com/bbs2/index.php?showtopic=2... Mar 19 2015, 10:25 PM
Cuda911 Thks again, I sent him a PM. Mar 19 2015, 10:37 PM
Larmo63 http://www.jwesteng.com/shop/index.php?id_...troll... Mar 20 2015, 08:40 AM
Dave_Darling Here's a place that has the Pilot lights:
htt... Mar 20 2015, 10:05 AM
OK, I purchased the lights from PCA... Mar 20 2015, 03:04 PM
screenguy914
Thanks, guys.
OK, I purchased the lights from PC... Mar 21 2015, 03:12 PM
Dave_Darling Heh, Sergio is local to me. He was one of my auto... Mar 20 2015, 07:34 PM
Cuda911 Thanks. Once I have all my stuff assembled, I... Mar 21 2015, 07:35 PM
Larmo63 The hole is there, you will find it. Mar 21 2015, 10:58 PM
Cuda911
Perfecto, ... Mar 22 2015, 10:32 AM
screenguy914 To complete my project posted at #16, I removed th... Mar 27 2015, 01:28 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:58 AM |
