Building a driver, Speculating about the changes |
venturadeb |
Aug 10 2014, 10:38 PM
Newbie Group: Members Posts: 10 Joined: 10-August 14 From: Ventura Ca Member No.: 17,761 Region Association: Southern California |
I am 54 years old, and terminally ill with Pulmonary fibrosis (A very nasty disease). All my life I have wanted a 914, and the opportunity never got there. I am now looking at a small amount of cash, and thinking of building one.
Here is the problems, and some ideas: 1) I am 6'3" and not very mobile anymore 2) I am on oxygen 24/7 and need a place for my oxygen concentrator. I have thought about the following modifications 1) lengthen the car about 12 inches 2) modify the top so it opens like a "gull wing" when in place 3) raise the top about 3 to 4 inches (as a top structure, not a change to the pillars) 4) create a hydraulic lift that would "ejector style" raise the seat 6-8 inches for entry, and lower into place for driving 5) obviously move the seat back to accommodate a taller driver By doing these things, I would be able to move the seat back, to accommodate my longer legs, and still keep room for an oxygen concentrator, and a passenger in the car. It would accommodate my reduced mobility, and still be able to get into and out of the car. Questions: In lengthening the car by up to 12 inches, how much weight would be added to support this change? how hard would this be to engineer? I am not able to do the work myself, what kind of cost do you think would be involved in making these changes? (obviously, speculate with me (IMG:style_emoticons/default/beerchug.gif) ) How hard would it be to modify the door to lengthen it by 12 inches (and glass?) Would it keep the geometry of the car? One of the things I love about the 914 are the simple clean lines WHAT TO DO then? rebuild the drivetrain, complete bare metal paint job, premium leather on the seats, with offset color stitching, and matching leather on the dashboard with offset color stitching. Am I completely nuts, or could this be done with a reasonable amount of money to make a daily driver? |
ablesnead |
Aug 11 2014, 03:02 PM
Member Group: Members Posts: 157 Joined: 16-September 13 From: United States Member No.: 16,395 Region Association: None |
I can help with this..was in the med equipment business a long time..First you can get a seat lift designed to help you up from a regular chair..they are small enough to adapt...I have oxygen concentrators as small as 2 pounds ..what is your liter flow ?...you will need an inverter for the seat lift...concentrator is 12 volt...I am 6' 3" legroom is not a problem...do figure on a quick release for the steering wheel..it is easy and relatively cheap to move the shifter a few inches .The stuff I am talking about is under 4 grand I imagine.
venturadeb |
Aug 12 2014, 02:56 AM
I can help with this..was in the med equipment business a long time..First you can get a seat lift designed to help you up from a regular chair..they are small enough to adapt...I have oxygen concentrators as small as 2 pounds ..what is your liter flow ?...you will need an inverter for the seat lift...concentrator is 12 volt...I am 6' 3" legroom is not a problem...do figure on a quick release for the steering wheel..it is easy and relatively cheap to move the shifter a few inches .The stuff I am talking about is under 4 grand I imagine. WOW! The ideas have been great! I am on 2L when Sitting, and 6L when walking. Driving? LOL Sounds like I could get a little leg room with changing the leg well, add a seat lift, and mount a concentrator (12V) in the trunk with tubing connectors in the cabin. I still have mobility problems with my neck, so modifying the Targa top to open like a "gull wing" should be done to give me the ability to drive with the top on. all relatively minor modifications, without cutting the car in half. Although I still think lengthening the body would be cool, I would never get my money back, and it is an expensive proposition. |
Dave_Darling |
Aug 12 2014, 08:03 AM
all relatively minor modifications, without cutting the car in half. Cutting the car in half should be avoided--pretty much at all costs. The 914 Limo is an example of why: Even with the full facilities of a professional shop at hand, plus periodic free labor, the car still isn't even close to driveable. It takes a ton of work to do, and you need a really dedicated owner with very deep pockets indeed to actually complete the project. --DD |
SirAndy |
Aug 12 2014, 11:40 AM
Resident German Group: Admin Posts: 41,677 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
The 914 Limo is an example of why: Even with the full facilities of a professional shop at hand, plus periodic free labor, the car still isn't even close to driveable. It takes a ton of work to do, and you need a really dedicated owner with very deep pockets indeed to actually complete the project. Actually, no, it's not a good example. None of the points you make actually apply to the 914World Limo. And just for the record, it's not that far from driving under it's own power. The only real problem with the Limo is time, something both Mark and i have had little to spare in the last few years to actually finish this project. (IMG:style_emoticons/default/shades.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 12:22 PM |
