> Fuel accumulator?, Trouble at tight corners
worn
post Aug 10 2014, 05:16 PM
Today at an autocross meet the car was doing great. EXCEPT that after a sharp curve there was a delay in getting power, with he engine running lean. We were running a half tank or less to save on weight and it was suggested that the problem was fuel starvation after a sharp turn.
Having looked inside the tank it don't seem so awfully likely, but it does fit the symptoms. Driving back on country roads I went across several 90 degree bends, and the same durn thing happened! (IMG:style_emoticons/default/hissyfit.gif) Any thoughts?
Mike Bellis
post Aug 11 2014, 06:35 PM
Resident Electrician
I would start with a new higher volume FI pump. A fuel accumulator requires a tank and a secondary fuel pump. There should be no need for an accumulator at your HP level. You should also replace the pressure regulator.
Also make sure your supply and return in the tank are not reversed.
Do you have this problem with a full tank?
BTW, I'm running a single pump in the front and a +300hp turbo motor and don't have this issue.
post Aug 11 2014, 08:34 PM
Resident German
QUOTE(Mike Bellis @ Aug 11 2014, 05:35 PM) *
I would start there. If it still happens with a full tank something else is going on.
If it is related to fuel level in the tank, you could try to add some baffle to the tank. That would require opening the tank but should work well enough.
worn
post Aug 15 2014, 08:11 PM
QUOTE(SirAndy @ Aug 11 2014, 06:34 PM) *
I guess I was wondering if it had happened to anyone before. It is a relatively new FI set of components, and yes, I think it does depend on fuel level. But this is a tank I treated with rust removers and rotary nuts and bolts. I ran it with a bar b q rotisserie for a couple of days and yes, I did count the nuts and bolts both ways. I was impressed by the baffles already present. Any chance the bucket for the fuel return isn't quite enough? I am running at 32 psi, which is slightly high, and I also notice how the tank is very transverse. It is right at the front wheels, so there is good reason for all of the fuel to migrate left or right. Then after the turn - disappointment!
JamesM
post Aug 15 2014, 08:57 PM
The tank already has some baffles in it, adding more would probably be more trouble then it is worth.
Where is your pump located? Is it an old 3 port or a new replacement?
I had a similar condition but it was not due to fuel slosh but rather shifting and pinching of the fuel supply lines between the tank / filter / pump.
- Lo-Fi Version Time is now: 17th July 2025 - 05:31 AM
