Which of our Vendors Sells 0 280 130 003-or-0 280 130 012, HTC for 73 2.0 In preperation for the RRC Also need a T-Stat |
rick 918-S |
Aug 17 2014, 07:03 PM
Hey nice rack! -Celette Group: Members Posts: 20,492 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
We plan to take Sandy's car to the RRC this time. The top end rebuild has like 2k since install.
I'm dealing with a constant rich condition and want to install a new head temp sensor. I have the ballast in place. I plan to check the timing. I will check for tight valve adjustment just in case but I think that's fine. Also idle is inconsistent. This could be partially the fault of the T-Stat not working. So I need one of those also. I have a known good AAR incase the one in the car tests bad. I tested the MAPS. It holds vacuum and is the correct part # as is the ECU. Final issue is the charging system. It seems to be fine but when you step on the brakes or flip on the signals or light the voltage drops. I think I have a bad ground someplace. I have a new transaxle strap and the main ground next to the relay board is clean and tight. Any suggestions where I should start? Also any other suggestions are welcome. P.S. Pelican lists the HTS but I'm not sure it's the correct one for the 73 2.0 GPR's listing specifies 1.7 engine. Sierra no listing. |
914Sixer |
Aug 17 2014, 07:21 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Autohausaz has cylinder head temp sender 0 280 130 12 for $11.61.
rick 918-S |
Aug 17 2014, 07:57 PM
Lo-Fi Version | Time is now: 8th June 2024 - 08:07 AM |
