What's the point of the little plastic plugs in the trunk bed? |
Cuda911 |
Aug 18 2014, 02:13 AM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
There are three of them under the foam liner. (well actually, I only have two... anyone know where I can find one? I know they are not needed, but I want to make this car as "complete" as possible). Why did Porsche bother designing these holes and then design plugs for them? Drain holes in case I want to use the trunk as a kiddy pool? Also, one is a bit smaller than the other two, and appears to be threaded. Have a plug you can spare? Thanks! . Attached image(s) |
Cuda911 |
Aug 18 2014, 10:25 AM
So with the threaded one, the idea is that I can choose whether I want the spare in the front or the rear?
Back to the other two holes/plugs: Anyone else know? Pete, an interesting guess, but it can't possibly be correct. First of all, the plugs are meant to be left in place. By your theory, I would need to remove them to easily close the trunk. Second of all, they are below the foam pad and the carpet, which would block air flow through them. |
dlkawashima |
Aug 18 2014, 12:52 PM
914 Guru Group: Members Posts: 9,749 Joined: 1-October 10 From: San Jose Member No.: 12,234 Region Association: Northern California |
RFoulds |
Aug 18 2014, 02:52 PM
Green Teen 66 Group: Members Posts: 837 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region |
My guess is drains., the front trunk has them as well, and it also has 2 holes with tubes that drain out.
Lo-Fi Version | Time is now: 8th June 2024 - 11:50 AM |
