| JawjaPorsche |
Jan 16 2012, 04:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I see where the Tapered Fuel Hose is no longer available at Pelican Parts:
http://www.pelicanparts.com/cgi-bin/smart/...74%29%2C%20Each Does anyone know an alternative source? Also dumb question. The description says "Tapered Fuel Hose For Connection at Fuel Filter." I thought the hose was also used for the outlet port on the fuel pump because the connection is smaller than the standard hose size: 8 mm? |
| stinkindiesel |
Aug 19 2014, 03:45 PM
Member ![]() ![]() Group: Members Posts: 184 Joined: 14-June 13 From: Georgetown, TX Member No.: 16,012 Region Association: Southwest Region |
Has anybody identified a suitable fuel filter with 3/8" inlet and outlet? This would save trying to round up a weird hose or adapter. After all, you usually need this when replaciing the filter anyway...
Looks like a Wix 33033 might get you there? Gary |
| Kansas 914 |
Aug 19 2014, 07:51 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,006 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
Has anybody identified a suitable fuel filter with 3/8" inlet and outlet? This would save trying to round up a weird hose or adapter. After all, you usually need this when replaciing the filter anyway... Looks like a Wix 33033 might get you there? Gary I used to buy mine from Brad at 914ltd.com. He doesn't list it anymore but it was a Wix 33274. Summit racing has them for $5. http://www.summitracing.com/parts/wix-3327...CFQaCMgodnAEAXA |
| stinkindiesel |
Aug 20 2014, 07:47 AM
[/quote]
I used to buy mine from Brad at 914ltd.com. He doesn't list it anymore but it was a Wix 33274. Summit racing has them for $5. http://www.summitracing.com/parts/wix-3327...CFQaCMgodnAEAXA [/quote] Yep, the WIX 33274 is the correct one that has the 8mm inlet and 10mm outlet and needs the reducing adapter hose. I have one of those sitting right here. The old one I pulled out of the car looks identical to the 33274, except it has 8mm inlet and outlet. Wish the part number was visible, but it's worn off. It's a Mahle, but that's all I can make out. BTW, I looked up the Fram G-15 cross on the WIX web site. It does indeed cross to a 33033. Looking more closely at the specs, though, I see the WIX 33033 rated at 20 microns and the Fram G-15 at 10 microns. I think the Fram G15 is the winner! If you happen to be at one of those FLAPs that kind find their own a$$ without looking it up on their computer, just ask them for a fuel filter for a 1973 BMW 2002. Gary |
| ChrisFoley |
Aug 20 2014, 08:30 AM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
Yep, the WIX 33274 is the correct one that has the 8mm inlet and 10mm outlet and needs the reducing adapter hose. 33274 is the filter for the late (75-76) fuel system. It has a 8mm inlet and 12mm outlet. 33003 has 9.5mm inlet and outlet. 33002 has 8mm in and out. AFAIK Wix doesn't have one with a 9.5mm inlet and 8mm outlet. |
| stinkindiesel |
Aug 20 2014, 12:22 PM
Yep, the WIX 33274 is the correct one that has the 8mm inlet and 10mm outlet and needs the reducing adapter hose. 33274 is the filter for the late (75-76) fuel system. It has a 8mm inlet and 12mm outlet. 33003 has 9.5mm inlet and outlet. 33002 has 8mm in and out. AFAIK Wix doesn't have one with a 9.5mm inlet and 8mm outlet. Thanks Chris. That makes sense. I just know the 33274 was "just right" and "too big." I hadn't actually measured the connections. The 33003 and 33033 are essentially the same, with the 33003 being plastic and the 33033 being metal. Same filter element inside. |
JawjaPorsche Tapered Fuel Hose Jan 16 2012, 04:55 PM
billh1963 I thought it was only for the fuel tank line comin... Jan 16 2012, 05:12 PM
wingnut86 Check Automation and Vertex.
They used to carry t... Jan 16 2012, 05:50 PM
type47 Chris Foley sells a stainless steel piece that doe... Jan 16 2012, 06:12 PM
Racer Chris
Chris Foley sells a stainless steel piece that do... Jan 16 2012, 06:42 PM
SLITS Gad, go to ACE Hardware or a place like that and g... Jan 16 2012, 06:47 PM
Cap'n Krusty
Gad, go to ACE Hardware or a place like that and ... Jan 16 2012, 08:19 PM
SLITS
Gad, go to ACE Hardware or a place like that and... Jan 17 2012, 10:23 AM
dangrouche I employ Chris' taper stainless adaptor tubing... Jan 16 2012, 07:46 PM
rick 918-S
I employ Chris' taper stainless adaptor tubin... Jan 17 2012, 12:03 AM
ClayPerrine If IIRC, there is a Mercedes Diesel hose that wor... Jan 17 2012, 10:30 AM
Phoenix914
If IIRC, there is a Mercedes Diesel hose that wo... Aug 5 2014, 11:12 AM
Dave_Darling Your hardware store will have hose barbs and fitti... Aug 5 2014, 01:27 PM
Phoenix914 Thanks Dave. I'll probably go that route.
Th... Aug 5 2014, 01:34 PM
pete000 Glad I got one a few years back when I started my ... Aug 5 2014, 02:16 PM
Phoenix914
good grief I need to get my car going again ... Aug 5 2014, 02:39 PM
bdstone914
good grief I need to get my car going again ... Aug 5 2014, 06:58 PM
Phoenix914
I made one out of a piece of hose that was the co... Aug 5 2014, 07:24 PM
Racer Chris Trying to find that tapered hose is a waste of tim... Aug 5 2014, 03:14 PM
mepstein I bought mine from Chris - Tangerine. He has all t... Aug 5 2014, 08:06 PM
pete000 I noticed Sierra Madre lists them as NLA now too..... Aug 6 2014, 11:18 PM
Phoenix914 That looks like a nice piece, and cheaper than a M... Aug 7 2014, 05:09 AM
Racer Chris That Jegs piece is perfect. Aug 7 2014, 06:16 AM
Phoenix914
Looks like it might... Aug 7 2014, 06:22 AM
Racer Chris
Looks like it migh... Aug 7 2014, 07:45 AM
Dave_Darling
Has anybody identified a suitable fuel filter wit... Aug 19 2014, 09:09 PM
pete000 Fram makes an all metal filter with the 3/8 (10mm)... Aug 19 2014, 09:07 PM
mapguy Awesome!
That Wix unit is just the ticket... Aug 19 2014, 11:01 PM
bandjoey Bought one like the wix. Don't remember the br... Aug 20 2014, 07:55 AM
Phoenix914 Has anybody used this WIX filter? The description... Nov 18 2014, 10:06 AM
Racer Chris
Has anybody used this WIX filter? The descriptio... Nov 18 2014, 11:25 AM
Phoenix914
Wix 33002 is a better choice. 8mm inlet and outl... Nov 18 2014, 01:15 PM
dcheek VW uses a similar hose. I ordered one for one of m... Nov 18 2014, 02:34 PM
Mikey914 I personally don't like Wix. I had a problem w... Nov 18 2014, 11:59 PM
dcheek This is the one I used on my Rabbit a while back. ... Nov 19 2014, 03:27 PM
Phoenix914 This listing says the hose is 7/11 mm. :idea:
... Nov 19 2014, 04:10 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:34 AM |
