914-6 oil filler neck, Something has never been right on my car. |
ClayPerrine |
Aug 23 2014, 07:45 PM
Life's been good to me so far..... Group: Admin Posts: 15,520 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Ok.. I have a question for those of you who have a six.
The filler neck on my six oil tank has never fit just right. It always seems a bit loose and floppy (no jokes here guys, I am serious). I was trying to replace the rubber connector between it and the tank, and it doesn't seem right either. And the last thing that has me questioning this is it always seems like I have too much oil in the tank when I fill it to the mark on the dipstick. The dipstick, tank and filler neck are all factory Porsche parts. The rubber boot does not reach the bulge in the filler neck, and the assembly has always looked wrong. My question... Is the filler neck supposed to slide into the tank opening, or does it just butt up against the tank? All the evidence I have with the oil level and the filler flopping around make me think it should slide into the opening on the tank. But it doesn't quite fit inside. |
sixnotfour |
Aug 24 2014, 11:54 AM
914 Wizard Group: Members Posts: 10,436 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Here is a 911 neck and you need two hose clamps and a thick hose, If the area before the bead roll is the same diameter all the way up to the bead then either
clamp system will work and be stable as it goes deeper into the tank neck and is a 914-6 filler neck...... (IMG:style_emoticons/default/smile.gif) Attached image(s) |
ClayPerrine |
Aug 24 2014, 12:15 PM
Here is a 911 neck and you need two hose clamps and a thick hose, If the area before the bead roll is the same diameter all the way up to the bead then either clamp system will work and be stable as it goes deeper into the tank neck and is a 914-6 filler neck...... (IMG:style_emoticons/default/smile.gif) That is what I was saying in my first post. Mine won't go into the tank neck. It butts up flush with the tank neck. Guess I know now that it is supposed to slide inside the tank neck. |
Lo-Fi Version | Time is now: 9th June 2024 - 11:28 PM |
