Which comes first: Straightening the tub or structural rust repair? |
doug_b_928 |
Aug 28 2014, 06:16 AM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I've been disassembling my car and getting a better sense of what happened to it before my ownership. I think the car was hit on the left rear corner. It doesn't appear that it crumpled much at all. In fact, the left taillight assembly was re-used (the black plastic on the end is missing a 1 cm piece and there's a crack in the middle of the black plastic on the back). There's also a really bad bondo repair about the diameter of an average hand by the tailight. So I don't think much crumple-type of damage was done. But, that hit must have somehow twisted the chassis by either pushing the left rear down and/or pushing the right rear up. There is a big difference in height left to right when looking at the rear end (like 1 -1.5"). The suspension ear on the right is 4mm higher than the one on the left. The latter might even be within factory spec, no? Also, the distance between the trunk channels on the rear fenders is within spec for the front half, but the back half progressively narrows to being 1.5cm too narrow.
The longs, rockers, firewall and hell hole are shot and the door gaps by the door handles are too big (8-9mm). So, I'm wondering, (aside from the option of scrapping it), do I get the chassis straightened before metal surgery, or after surgery on the main structural parts? I could see the former tearing the car apart, and the latter creating imperfections in the newly repaired work. |
doug_b_928 |
Aug 29 2014, 02:05 PM
Putting it on a Celette aside for the moment, do the data provide any useful information about where it's out and why the door gaps are the way they are? Am I understanding the "f" measurement correctly in terms of the windshield flange (i.e., I'm measuring it as the point of the flange where the windshield rubber seal sits)? If so, how can there be such a big gap by the door handles if "f" is in spec (or even too tight)?
SirAndy |
Aug 29 2014, 04:19 PM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Putting it on a Celette aside for the moment, do the data provide any useful information about where it's out and why the door gaps are the way they are? Am I understanding the "f" measurement correctly in terms of the windshield flange (i.e., I'm measuring it as the point of the flange where the windshield rubber seal sits)? If so, how can there be such a big gap by the door handles if "f" is in spec (or even too tight)? Measuring from the top of the windshield frame is pretty much useless as the frame bends too easy. You can grab the top corner on either side and easily move it with your hand. In fact, a lot of people grab that edge to pull themselves out of the car and overtime can easily bend that edge down. Look for reference points that are in areas that are more sturdy. Any place where you would expect a perfect X as a result will do. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 7th June 2024 - 07:54 AM |
