> Penetrating oil test
puffinator
post Aug 31 2014, 01:47 PM
I got this via another car guy forum.
For All of you Mechanic's and Self doer’s out there.
Penetrating Oil - interesting
This was in one of the Military Vehicle Club newsletters
Here is an interesting article submitted by Bob Muller for our members consideration
Penetrating Oils
Recently “Machinist Workshop Magazine” did a test on penetrating oils. Using nuts and
bolts that they ‘scientifically rusted’ to a uniform degree by soaking in salt water, they then
tested the break-out torque required to loosen the nuts. They treated the nuts with a variety
of penetrants and measured the torque required to loosen them.
This is what they came up with:
Nothing: 516 lbs
WD-40: 238 lbs;
PB Blaster: 214 lbs;
Liquid Wrench: 127 lbs,
Kano Kroil: 106 lbs
(ATF)/Acetone mix (50/50): 50 lbs.
This last “shop brew” of 50% automatic transmission fluid and 50% acetone appears to beat
out the commercially prepared products costing far more.
Jake Raby
post Sep 1 2014, 01:38 PM
Engine Surgeon
They should have tried melted paraffin, too.. That along with the acetone/ ATF is what I've always used. Three years ago I started working on freeing up the impellers of a very old hydro electric power plant, and nothing would work except the ATF/ Acetone trick.
After 3 months we got it back up and running again.
- Lo-Fi Version Time is now: 13th July 2025 - 11:46 AM
