> Penetrating oil test
puffinator
post Aug 31 2014, 01:47 PM
I got this via another car guy forum.
For All of you Mechanic's and Self doer’s out there.
Penetrating Oil - interesting
This was in one of the Military Vehicle Club newsletters
Here is an interesting article submitted by Bob Muller for our members consideration
Penetrating Oils
Recently “Machinist Workshop Magazine” did a test on penetrating oils. Using nuts and
bolts that they ‘scientifically rusted’ to a uniform degree by soaking in salt water, they then
tested the break-out torque required to loosen the nuts. They treated the nuts with a variety
of penetrants and measured the torque required to loosen them.
This is what they came up with:
Nothing: 516 lbs
WD-40: 238 lbs;
PB Blaster: 214 lbs;
Liquid Wrench: 127 lbs,
Kano Kroil: 106 lbs
(ATF)/Acetone mix (50/50): 50 lbs.
This last “shop brew” of 50% automatic transmission fluid and 50% acetone appears to beat
out the commercially prepared products costing far more.
Cuda911
post Sep 1 2014, 09:56 AM
Hmmm... neither acetone nor ATF are particularly hazardous. I can't see any reason why that mixture couldn't be sold. There are tons of companies that can blend it and package it, and even generate an MSDS.
I'm smelling some entrepreneurial opportunity here.
ripper911
post Sep 1 2014, 01:22 PM
corde pulsum tangite
QUOTE(Cuda911 @ Sep 1 2014, 11:56 AM) *
Is it a mixture that would remain stable for long enough periods to be packaged and sold, out would it go bad somehow?
Cuda911
post Sep 1 2014, 04:58 PM
QUOTE(ripper911 @ Sep 1 2014, 12:22 PM) *
No reason at all that it shouldn't be stable. As stated above, it's likely that the acetone serves as a solvent carrier to get the ATF into crevices.
A spray can with a thin tube like WD-40's should work fine.
So, shall we crowd-source this?
Here's even a link to the formula:
https://www.engineeringforchange.org/news/2...rating_oil.html
More info:
http://machinistchest.blogspot.com/2014/01...enetrating.html
- Lo-Fi Version Time is now: 13th July 2025 - 11:51 AM
