Electrical Gremlins - Fuse 8 fried, no brake lights, again |
tadink |
Sep 4 2014, 03:50 PM
Member Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
Hey all -
I've done some research on the forum and looked at most / all of the electrical troubleshooting guides - but my issue has me stumped..... 71 Tub, 2.0L engine My fuse 8 fries when the headlamps are turned on - but works fine otherwise. Well, it also fries when the wiper motor is turned on - so something is not right. Other symptoms: When turn indicators are 'on' the e-brake big red light flashes Upon inspection - I see that there is a jumper from my fuse 8 to fuse 9, I don't see that shown on any of the wiring diagrams I've looked at. You can see it in the pic below - a black wire from 8 to 9. Some clever PO had a stereo system in there and much of the electronical connections are a bit 'non standard' but the stereo is long gone. I don't have an e-brake and so the e-brake sensing wire is not attached. As you can see from the attached pic of the fuse 8, it is not just fried but MELTED too! yipes. Any thoughts on a process forward from here??? Can you tell anything by looking at the fuse panel that a newb like me won't notice? note: I did get in there an clean the grounding point while I was upside down under the dash.... thanks in advance.... td |
Mike Bellis |
Sep 4 2014, 07:52 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I had a problem with #8 and tracked it down to the brake switch grounding out.
Lo-Fi Version | Time is now: 9th June 2024 - 02:59 AM |
