odd wear marks on flywheel |
rjames |
Sep 10 2014, 12:31 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Bought this flywheel new last summer and have put less than 1000 miles on it.
I don't remember seeing these marks when I installed it. What would cause this? I don't see any marks on the case. Also, besides the rear main seal leaking, it looks like I'm getting some leaking from the gallery plugs (I think that's what these are called). They appear to be in tight. Is it advisable to remove them and put some sort of sealant on them? |
r_towle |
Sep 10 2014, 01:27 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
my comment was a guess on the marks.
Its hard to tell where the marks are that you are talking about....at least for my old eyes. rich |
rjames |
Sep 10 2014, 02:10 PM
wndsrfr |
Sep 10 2014, 05:39 PM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
my comment was a guess on the marks. Its hard to tell where the marks are that you are talking about....at least for my old eyes. rich Rich, I can relate. I've circled the marks in red. I think a screw got in there....probably made those marks the first time the engine turned over and tore the lip of the seal as well...rattled around a bit making pocks further out on the flywheel before being ejected.... |
rjames |
Sep 10 2014, 06:20 PM
my comment was a guess on the marks. Its hard to tell where the marks are that you are talking about....at least for my old eyes. rich Rich, I can relate. I've circled the marks in red. I think a screw got in there....probably made those marks the first time the engine turned over and tore the lip of the seal as well...rattled around a bit making pocks further out on the flywheel before being ejected.... Hmmm the seal was perfectly fine. No marks. I'm 100% sure there wasn't a screw dropped in there. I suppose there could have been a small piece of metal debris though? I really want to verify all is good before I put everything back together. Do I need to worry about resurfacing the flywheel where it's marked up? |
wndsrfr |
Sep 10 2014, 06:52 PM
Something that catches my eye is that the entire shoulder is polished clean as if it's been rubbing on the face of the seal. That doesn't look right to me....like the seal isn't seated in far enough. There should be some clearance there, right? In which case, if the flywheel is hitting the seal face, it's giving you a false reading on the endplay of the crank....the thrust face of the bearing is what it's got to be limited by. Repeat your endplay measurement without the seal in place first....then install the seal far in enough such that the endplay doesn't change & you'll have it nailed.
As long as the surface that the seal lip rides on is smooth, no reason to do anything to it....mount new seal & go! |
Lo-Fi Version | Time is now: 9th June 2024 - 08:49 AM |
