I need a radiator for my SBC conversion, Ideas? Part numbers? |
pete |
Jun 21 2011, 10:52 AM
Member Group: Members Posts: 158 Joined: 23-August 10 From: New Jersey Member No.: 12,092 Region Association: North East States |
I need to purchase a radiator for my SBC conversion and am in need of some suggestions/part numbers. JEGS? Also, will need a over flow canister and hoses.
speed metal army |
Sep 10 2014, 10:30 PM
Waiting for the rain to stop... Group: Members Posts: 1,068 Joined: 4-September 10 From: PNW Member No.: 12,137 Region Association: Canada |
Don't forget flow! The rad needs to be big enough, but you also have to move the coolant to cool properly. Mike Bellis is running a really cool water pump(Mike?What kind again?)Lots of GPH + properly sized rad and fans = cool. Im running a renegade LS cooling kit that also uses an electric pump, and I have zero cooling issues. The renegade kit works, but it can be done way cheaper. Also, the better you can shroud the inlet side of your rad, the better.
Mike Bellis |
Sep 10 2014, 11:20 PM
Don't forget flow! The rad needs to be big enough, but you also have to move the coolant to cool properly. Mike Bellis is running a really cool water pump(Mike?What kind again?)Lots of GPH + properly sized rad and fans = cool. Im running a renegade LS cooling kit that also uses an electric pump, and I have zero cooling issues. The renegade kit works, but it can be done way cheaper. Also, the better you can shroud the inlet side of your rad, the better. Super cool pump... (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 13th June 2024 - 06:58 AM |
