> eBrake won't set, Took it apart- see pics Monday
jim_hoyland
post Sep 13 2014, 08:51 PM
Get that VIN ?
It's a late car; when I pull up on the eBrake handle it doesn't set. It will go back down to the floor. Is a part sticking ?
partwerks
post Sep 13 2014, 08:53 PM
QUOTE(jim_hoyland @ Sep 13 2014, 06:51 PM) *
It would make ya think that something is not catching? I've never had one apart. I would assume there are some sort of notches, as I recall it clicks.
I have a hydraulic one.
jim_hoyland
post Sep 13 2014, 09:02 PM
Get that VIN ?
QUOTE(partwerks @ Sep 13 2014, 07:53 PM) *
That's right: it's not catching.... (IMG:style_emoticons/default/sad.gif)
ndfrigi
post Sep 13 2014, 09:10 PM
QUOTE(jim_hoyland @ Sep 13 2014, 08:02 PM) *
Hi Jim, I think it just need some oil inside the handle.
jim_hoyland   eBrake won't set   Sep 13 2014, 08:51 PM
partwerks   It's a late car; when I pull up on the eBrake...   Sep 13 2014, 08:53 PM
jim_hoyland   It's a late car; when I pull up on the eBrak...   Sep 13 2014, 09:02 PM
ndfrigi   [quote name='partwerks' post='2085775' date='Sep ...   Sep 13 2014, 09:10 PM
Cap'n Krusty   It's a late car; when I pull up on the eBrak...   Sep 14 2014, 09:01 AM
mepstein   mine wasn't catching. I took it out of the car...   Sep 13 2014, 09:07 PM
bdstone914   It's a late car; when I pull up on the eBrake...   Sep 13 2014, 09:17 PM
jim_hoyland   It's a late car; when I pull up on the eBrak...   Sep 13 2014, 09:37 PM
914_teener   Bruce, Sounds like the spring is Kaput. I don...   Sep 13 2014, 09:37 PM
bdstone914   Bruce, Sounds like the spring is Kaput. I don...   Sep 13 2014, 09:53 PM
76-914   Jim, unscrew the blk plastic knob and look. Sounds...   Sep 14 2014, 07:26 AM
jim_hoyland   Unscrewed the button and pulled the spring; spring...   Sep 14 2014, 08:21 AM
Cap'n Krusty   Unscrewed the button and pulled the spring; sprin...   Sep 14 2014, 10:17 AM
mepstein   Unscrewed the button and pulled the spring; sprin...   Sep 14 2014, 04:13 PM
jim_hoyland   A seat removal is required ?   Sep 14 2014, 10:35 AM
mepstein   A seat removal is required ? eisier to do with t...   Sep 14 2014, 12:23 PM
bdstone914   [quote name='jim_hoyland' post='20859...   Sep 14 2014, 03:52 PM
worn   You are going to have to replace the handle. I ...   Sep 15 2014, 04:21 PM
Dave_Darling   Maybe not, but it makes access easier, and it take...   Sep 14 2014, 12:20 PM
bdstone914   Here is the layout of the parts.   Sep 14 2014, 04:28 PM
jim_hoyland   Here is the layout of the parts. Which parts a...   Sep 14 2014, 06:36 PM
914_teener   Here is the layout of the parts. Which parts ...   Sep 14 2014, 09:43 PM
jim_hoyland   [quote name='jim_hoyland' post='2086113' date='Se...   Sep 15 2014, 06:37 AM
SLITS   Here is the layout of the parts. Which parts ...   Sep 16 2014, 01:10 PM
jim_hoyland   [quote name='jim_hoyland' post='2086113' date='Se...   Sep 16 2014, 03:46 PM
jim_hoyland   Is the rod and piece on the right end one piece ?   Sep 14 2014, 06:31 PM
Cap'n Krusty   No. The Cap'n   Sep 14 2014, 06:34 PM
jim_hoyland   Dissassembled the handle from the body. The rod an...   Sep 15 2014, 02:32 PM
jim_hoyland   Reassembled after inspection; looks like the teeth...   Sep 15 2014, 03:29 PM
worn   Reassembled after inspection; looks like the teet...   Sep 15 2014, 04:18 PM
Cap'n Krusty   Does the pawl move with the rod? (The rod and paw...   Sep 15 2014, 04:07 PM
worn   It's a late car; when I pull up on the eBrake...   Sep 15 2014, 04:15 PM
jim_hoyland   I can' detach the assembly from the cable at t...   Sep 15 2014, 04:33 PM
SLITS   I can' detach the assembly from the cable at ...   Sep 15 2014, 05:54 PM
jim_hoyland   I have a late (75) handle; in reading a pat postin...   Sep 16 2014, 07:21 AM
MoveQik   Jim, I think this is all a sign that you let your ...   Sep 16 2014, 03:53 PM
jim_hoyland   Jim, I think this is all a sign that you let your...   Sep 16 2014, 06:15 PM
- Lo-Fi Version Time is now: 6th July 2025 - 02:32 PM
