> KEP pressure plate issue- Subaru swap
roachghia70
post Sep 14 2014, 04:35 PM
I just tore my car apart to track down my clutch issue. And this is what I found:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i255.photobucket.com-2153-1410734105.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i255.photobucket.com-2153-1410734105.2.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i255.photobucket.com-2153-1410734106.3.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i255.photobucket.com-2153-1410734106.4.jpg)
I think I had my clutch cable too tight. And with the pedal fully depressed, I was pushing the Throwout bearing so far that the second step was hitting the pressure plate. But with the clutch any looser, it wouldn't disengage and I couldn't get it into gear.
So it was basically impossible to adjust the clutch.
I've heard that maybe my pivot bolt needs to be shimmed.
I've also heard that some KEP V8 kits have incorrect geometry in them, causing you to have to shim the pivot bolt or modify the fork.
Anyone have that problem with Subaru KEP kits, or has anyone seen this type of pressure plate damage before? I'm about to order new parts, but I just want to understand the problem so it doesn't happen again.
Thanks for your help!
Mike Bellis
post Sep 14 2014, 07:52 PM
Resident Electrician
I don't think it was your cable too tight. Spacing the pivot can help if you're not disengaging enough. I guess it would change the geometry slightly but not solve that issue.
Clearly a self machining process started. I would first ask if the through out bearing seized? Maybe you are sitting still too long and not driving your car? Maybe that KEP pressure plate is a POS? Maybe you have the wrong bearing?
- Lo-Fi Version Time is now: 9th July 2025 - 04:29 PM
