roachghia70 |
Newbie ![]() Group: Members Posts: 49 Joined: 3-June 04 From: Santa Cruz, CA Member No.: 2,153 Region Association: Northern California ![]() |
I just tore my car apart to track down my clutch issue. And this is what I found:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i255.photobucket.com-2153-1410734105.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i255.photobucket.com-2153-1410734105.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i255.photobucket.com-2153-1410734106.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i255.photobucket.com-2153-1410734106.4.jpg) I think I had my clutch cable too tight. And with the pedal fully depressed, I was pushing the Throwout bearing so far that the second step was hitting the pressure plate. But with the clutch any looser, it wouldn't disengage and I couldn't get it into gear. So it was basically impossible to adjust the clutch. I've heard that maybe my pivot bolt needs to be shimmed. I've also heard that some KEP V8 kits have incorrect geometry in them, causing you to have to shim the pivot bolt or modify the fork. Anyone have that problem with Subaru KEP kits, or has anyone seen this type of pressure plate damage before? I'm about to order new parts, but I just want to understand the problem so it doesn't happen again. Thanks for your help! |
matthepcat |
Meat Popsicle ![]() ![]() ![]() Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California ![]() |
I think the problem is the universe is telling you to go Suby trans swap.
Lo-Fi Version | Time is now: 9th July 2025 - 04:45 PM |
