jim_hoyland |
Get that VIN ? ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,808 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California ![]() ![]() |
It's a late car; when I pull up on the eBrake handle it doesn't set. It will go back down to the floor. Is a part sticking ?
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Does the pawl move with the rod? (The rod and pawl are 2 separate pieces.) Order of assembly: rod, washer, spring, button. The rod goes over the pawl, which should pivot when you move the rod. If the teeth are nasty, clean 'em up with a file. It would be HIGHLY unusual for them to be worn enough to cause the parking brake not to work.
Good luck! The Cap'n |
Lo-Fi Version | Time is now: 6th July 2025 - 02:02 PM |
