Fuel Pump - Need Help, trying to fire up my barn find for first time...no fuel |
willimac |
Sep 14 2014, 07:48 PM
Newbie Group: Members Posts: 14 Joined: 14-September 14 From: minnesota Member No.: 17,901 Region Association: None |
I'll try to keep the story short. I have a '74 1.8 L-jetronic 914 that I rescued from a barn in central Wisconsin almost 3 years ago. It had sat for over 20 years and become a palace for generations of barn mice, who built nests in every available cavity. Since then I've been sporadically cleaning it up, vacuuming mice and their nesting material, dropping the engine, dismantling and rebuilding it, cleaning up rust, shopping new parts (alternator, starter, stainless fuel lines, seals and gaskets) re-boring the cylinders, splicing chewed-through wiring, etc... finally got it put back together this week and am having trouble with the fuel delivery. The fuel pump does not turn on.
There is power to the double relay switch - terminal 86a checks out with the ignition switch on start, zeros out in "on" position , and AFM resistance checks out. The terminals at the fuel pump plug read zero volts unless the ignition is turned to "start" and the AFM is propped open - in which case it reads 7 - 8 volts. Don't know what to do---is there a way to test the pump to see if I need to replace it? Why would only 8 volts be making it to the terminals for the pump? Is this possibly a problem with the double relay switch? Any help would be greatly appreciated...I feel very close to bringing this one back from the dead. |
timothy_nd28 |
Sep 15 2014, 05:05 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
K, double check the voltage at 88d on the dual relay.
willimac |
Sep 15 2014, 07:11 PM
K, double check the voltage at 88d on the dual relay. I did this by clamping a jump wire on the back of the plastic plug, with the dual relay still attached. 88d is the black/red wire on the ignition harness, right? ran test from that wire, through meter to neg battery terminal Voltage read 0 with ignition switch "on" and .03 to .04 with engine cranking. |
Lo-Fi Version | Time is now: 15th June 2024 - 11:59 PM |
