correct carpet 914-6, who is closest to correct |
porbmw |
Sep 19 2014, 12:54 PM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Still on the elusive hunt for correct/very close to correct carpet for a 1970 914-6
which, of course, appears to be a one year problem. I gather the 1970-6 had felt, different (probably not as nice) as what was supplied on the 4 cylinders...go figure.....and then in 71 Porsche decided to provide the 6 with the same prior years 914. IF I am incorrect, please let me know. Apart from the felt/carpet issue, there are other problems with the repro carpets out there, as follows; a)they seem to all bind the edges with black, when it shoudl be gray (grey up here) b)the heel pad usually is very inferior....BUT...ebay has "performance.900.1700 which APPEARS to have the correct heel pad, and c)the factory carpet had a stiff composition to it, with a whitish clear backing in a waffle shape that gave the carpet rigidity...(at least the carpet I have) Anyone know who "performance.900" is...and comments. Anyone have any better sources.... I know Mark of 914rubber apparently is making some kits....but haven't seen them. I did send him a sample of my 914-6 carpet, but don't know if that was of any help to him. Thanks Paul |
1970 Neun vierzehn |
Sep 19 2014, 09:06 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
Apart from the felt/carpet issue, there are other problems with the repro carpets out there, as follows; a)they seem to all bind the edges with black, when it shoudl be gray (grey up here) b)the heel pad usually is very inferior....BUT...ebay has "performance.900.1700 which APPEARS to have the correct heel pad, and c)the factory carpet had a stiff composition to it, with a whitish clear backing in a waffle shape that gave the carpet rigidity...(at least the carpet I have) Thanks Paul Paul, As to your conclusions, (IMG:style_emoticons/default/agree.gif) Attached is a close-up of a bit of my carpet from my 70/4, build date 01/1970. Back in the day, I had a friend who had a 70/6, and the carpet in his car was identical to mine. Your observations regarding the binding and backing material are correct. I cannot comment on repro carpet as I have not had the opportunity to compare it to my OEM pieces. Paul Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:05 PM |
