getting under the heat shield..., how the heck do you get in there? |
barebrad |
Sep 21 2014, 05:05 PM
Member Group: Members Posts: 54 Joined: 13-September 13 From: Huntsville, Al Member No.: 16,382 Region Association: South East States |
Alright folks, I've been cleaning, grinding and sand blasting all day. I'm trying trying to figure out how to get under the heat shield? Do you cut it out? Just leave it alone? (I'm to OCD to do that!) I'm thinking about cutting it out and weld in some studs and I can bolt it in after paint. What do most do?
Thanks |
barefoot |
Sep 21 2014, 06:58 PM
Senior Member Group: Members Posts: 1,281 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
there are 6 tabs with 2 spot welds each if you can pinpoint them and drill them out.
I had to replace the rear trunk panel, so cut around the 6 tabs and liberated the heat shield, then attached to the new trunk panel with SS pop rivets. |
malcolm2 |
Sep 22 2014, 12:56 PM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
there are 6 tabs with 2 spot welds each if you can pinpoint them and drill them out. I had to replace the rear trunk panel, so cut around the 6 tabs and liberated the heat shield, then attached to the new trunk panel with SS pop rivets. Rivets sound good. If you ever had to take it out, just drill them out. I took the "out of site" road. Stuck my wire brush in as far as I could reach, hit it with some primer and paint and called it DONE. On this piece there is nowhere for the water to sit and rust it out. The rust comes from the trunk acting like a dog bowl with water in it. I am a fan of the spot weld cutter mounted in a drill. All the metal is still there. When you go to put it back, just tack the old spot to the old hole, grind and paint. Clark |
barefoot |
Sep 22 2014, 05:30 PM
[quote name='malcolm2' date='Sep 22 2014, 02:56 PM' post='2089046']
[quote name='barefoot' post='2088826' date='Sep 21 2014, 07:58 PM'] there are 6 tabs with 2 spot welds each if you can pinpoint them and drill them out. I had to replace the rear trunk panel, so cut around the 6 tabs and liberated the heat shield, then attached to the new trunk panel with SS pop rivets. [/quote] Rivets sound good. If you ever had to take it out, just drill them out. I took the "out of site" road. Stuck my wire brush in as far as I could reach, hit it with some primer and paint and called it DONE. On this piece there is nowhere for the water to sit and rust it out. The rust comes from the trunk acting like a dog bowl with water in it. I am a fan of the spot weld cutter mounted in a drill. All the metal is still there. When you go to put it back, just tack the old spot to the old hole. Here is photo of old trunk panel. you can see where i cut around the 6 tabs, this should get you close. Barefoot |
Lo-Fi Version | Time is now: 8th June 2024 - 11:00 AM |
